IMO your best bet is taking the car to a reputable tuner to get a compression and leak down test done... It should only cost $250 or so for a FULL inspection (including these tests), and it will tell you the condition of the most important part of the car - the engine! NRMA and mobile guys (that I know of!) wont do a compression test etc..
If the seller doesnt agree to take the car to a workshop to get it checked out, then he's probably got something to hide!
If you're a hard bargainer, you might be able to get him to take the cost of the test off the price of the car too :)
As NRMA I believe has stopped there mobile pre purchase vehicle inspection service. I was wondering if you guys can recommend any other reputable companies in sydney that do this?
Hey mate,
try and get someone who knows the cars rather than a standard inspection company.
When I was buying my first R33 (almost 9 years ago now), I had a so called NRMA expert spend a whole day going over a 33 I was interetsed in.
At the end of the inspection I got a report which graded the car in A1 condition apart from a few paint blemishes on the body. That same day after laying down a deposit I get a call from the seller, saying the car is running on 5 cylinders and that they would need 2 months to fix this and other issues (under warranty). They were quite cool and gave me back my deposit, but moral of the story is I would never trust a so called expert.
There are a fair few expert Skyline workshops who I would go too instead.
Just my 2c
Hey mate,
Just my 2c
Hence - why you need a compression test! :)
if its a basic car, like a run a round daily eg a vt commodore v6
id use VIP inspections otherwise, take it to a workshop that deals with those special cars
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
