Does anyone have some pics of a R32 GTR with 18" Works Emotion CR Kai's on them
Also does anyone know of a Glass polish that you can buy to use on the out side of your windows, I have a few light scratches in the passenger window where it has rubbed with the windows going up and down, since getting the windows tinted yesterday its very visable.
thanks
Edited by Mark0
https://www.sau.com.au/forums/topic/189921-r32-works-emotion-cr-kai/
i've hit my windows with polish/pads that i've used on my paintwork. (Menzerna polishes, and Edge Pads) got any polish products around?
not a good side on, but saw this over at ns.com (search for some matte/satin black threads here or at ns.com, there is definitely a side on of a 32 with the kai's)
i think these are kai's
That looks awesome, I was going to get a set i need to decide by the end of the weekend, but all the pics i have seen of them on 32's i think they look crap, the ones i was looking at are 18x9.5 +12 but I think The +12 offset will be to big for the 32 Guard, it will stick out to much, I want my wheels to sit flush or under the guards like this picture.
The tyres on them are 245/40.
Has anyone got opinions on this ? how they will look
See this is the pic i am basing my opinion on, I think it looks average it looks like the rims are to big or stick out to far.
these specs
9.5 x 18" +20
Falken FK451 265/35/18
Do you think the ones in the pic above are 17"
what do you recon ?
Edited by Mark0
these specs
9.5 x 18" +20
what do you recon ?
18's for sure.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
