as topic states. i have a sliding performance hiflow. non max oversize and she runs out of puff at 16psi on my 33 gtst
i thought they were rated to 19 psi?
im not very happy.
fixed the leaking plenum and runing 17...drops to 16 through the rev range. it dosent make any more power after 16.
only managed 231 rwk @ 16psi.
i have all the supporting mods too..injectors,z32afm...ect.
i was expecting alot more out of this turbo.
anyone else have this problem?
cheers
Edited by R33GOD
https://www.sau.com.au/forums/topic/189932-i-thought-slides-hiflows-hold-19psi/
  • Replies 46
it probably wont solve anything. im over spending money on power mods
just wanted to see if anyone has/ had the same problem with the turbo.
it is awesome to drive regardless of whats happening. i was just expecting more out of this turbo
I had the same probs... E-01 and all it would get to was 16-17psi... got it to 18 but ran out puff ... although I got 276 rwkw at the 18psi wringing its neck - ended up running around on 263rwkw @ 16-17psi...
Didn't worry about the lack of boost as I had reached the rwkw the turbo was rated at.... Since upgraded to a GT35R... Evil_weevil now has my old hi-flow!
16psi max seems a bit low for the turbo, thought youd be able to squeeze a cple more out of it. Ive got the same spec unit as you. being auto with piggybacks/stnd.injectors its about 40rwkw lower then yours at same boost. Mines got more in it tho.
bet you one thing tho - its bloody awesome on the street 'ey? if it aint broke dont fix it, or sell it and buy a name-brand item. for the price they are a good buy, understandable tho youd be pissed with the setup you have not being able to run that extra 1-2psi now and then. at the end of the day tho its just a power figure on a dyno, how it drives is another matter.......................................................
my Stagea is pretty much just nowfinished with the mods, very happy with my turbo choice selection. could have done better for twice the price but had a budget to stick to and will never regret using a Slide highflow. rounds off my overall package quite nicely.
i dont regret the turbo at all. just thought it had more in it. it spools up real quick and im happy with the power for the boost its at. but yea just wanted to run the maximum on it and squeeze more power out of it.
Edited by R33GOD
think im gonna take it back to him and run 13 psi again. i made close to 220 rwk on 13. least it will be safer :)
for the sake of 10-12rwk it'l be on 3 psi lesser, so meh
Edited by R33GOD
Hope you spoke to Aaron before questioning his products in forum?
i specifically said this isnt a flaming thread firstly.
i am satisfied on the performance if the turbo at this boost level and wanted to see if people with the same turbo had the same problem.
is freedom of speech not good for you?
what dump/front/cat/catback have you got?
custom bellmouth 3 inch front/dump stainless steel.
makes full boost by about 3400-3500 rpm.
i dont have a standard actuator, i have a hks one. the software in my ebc has been upgraded also
Edited by R33GOD
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
