if you have a look at the light assembly, you will notice the clear section is not as wide as the orange part. i think it was an option to have foglights. the series1's with foglights, have the clear section, the same width as the orange part (or ever slightly wider)... heres a pic
you will notice that the cars without fog lights will have the orange section taking up most of the assembly.
https://www.sau.com.au/forums/topic/18997-help-fog-lights/#findComment-399175
RedLineGTR
yeah it can be done, just probably need to put a globe in there, i havent had a look behind it.
hippy ive drawn a circle around the 'indicator/blinker' part, its got a bit of clear in it, but it's seperated by the other empty section
https://www.sau.com.au/forums/topic/18997-help-fog-lights/#findComment-399448
