hmmm... meg's site has most of them.. but its a bit all over the place..
basically the stuff you need to know about:
in 93-95 model standard are: aircon and digital climate control, elec mirrors, power steering, power windows, LSD
Optional: audio options, factory sunroof, ABS i think on 94 or 95, and I think drivers airbag is optional still in 95. All series 2 have drivers and passenger airbag.
Why do you care that it has to be a 1995 model??
https://www.sau.com.au/forums/topic/19001-r33-specs/#findComment-399118
There is various cross-over differences, where they started putting bits and pieces that appeared in the series #2 in the series #1.
I know what you mean though, mine is a 94 and dj_lethal's is like a 95 model.. and his has a lot of the series 2 stuff like different trim, etc.
https://www.sau.com.au/forums/topic/19001-r33-specs/#findComment-399129
try this
http://www.enovit.com/skyline/Nissan%20Sky...33%20GTS25t.htm
hosted from home, but nothing to do with my vehicle other than the fact it is an R33 GTS25t. Found it on the net a while ago and dug it up and stuffed around with a website, mail server, etc.
if there is anything other links, etc. that ppl want me to put up on the site, PM me.
hope this is what you are looking for!
https://www.sau.com.au/forums/topic/19001-r33-specs/#findComment-399370
Originally posted by predator666
sexc... i removed mine.. looks heaps better, esp with a dark tint.. i coulda removed the motor and everything but then i'd have to get the little hole filled.
oh yeah, but i put it back again.. coz its useful when its raining
Mines like that from the factory. There is no hole (where a motor would have been) and there are no rear wiper controls anywhere. I was told my car was a limited edition but I thinks its BS. I think it might have been a factory option not to have one.
https://www.sau.com.au/forums/topic/19001-r33-specs/#findComment-400729
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
