hmmm... meg's site has most of them.. but its a bit all over the place..
basically the stuff you need to know about:
in 93-95 model standard are: aircon and digital climate control, elec mirrors, power steering, power windows, LSD
Optional: audio options, factory sunroof, ABS i think on 94 or 95, and I think drivers airbag is optional still in 95. All series 2 have drivers and passenger airbag.
Why do you care that it has to be a 1995 model??
https://www.sau.com.au/forums/topic/19001-r33-specs/#findComment-399118
There is various cross-over differences, where they started putting bits and pieces that appeared in the series #2 in the series #1.
I know what you mean though, mine is a 94 and dj_lethal's is like a 95 model.. and his has a lot of the series 2 stuff like different trim, etc.
https://www.sau.com.au/forums/topic/19001-r33-specs/#findComment-399129
try this
http://www.enovit.com/skyline/Nissan%20Sky...33%20GTS25t.htm
hosted from home, but nothing to do with my vehicle other than the fact it is an R33 GTS25t. Found it on the net a while ago and dug it up and stuffed around with a website, mail server, etc.
if there is anything other links, etc. that ppl want me to put up on the site, PM me.
hope this is what you are looking for!
https://www.sau.com.au/forums/topic/19001-r33-specs/#findComment-399370
Originally posted by predator666
sexc... i removed mine.. looks heaps better, esp with a dark tint.. i coulda removed the motor and everything but then i'd have to get the little hole filled.
oh yeah, but i put it back again.. coz its useful when its raining
Mines like that from the factory. There is no hole (where a motor would have been) and there are no rear wiper controls anywhere. I was told my car was a limited edition but I thinks its BS. I think it might have been a factory option not to have one.
https://www.sau.com.au/forums/topic/19001-r33-specs/#findComment-400729
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
