We have been down this track just so often it's getting BORING!!!!!
The PJR cars of Glenn Seton & George Fury plus others ran 17 x 9 front and 17 x 10 rear with 240/625 front and 240/650 rear slicks.
For the uninformed these designations mean 240mm wide (bag to bag) same as in normal tyre sizing x 625 & 650mm diameter, that's overall static diameter.
The OPTIMUM tyre size is 245/45 x 16. This gives the largest footprint and is still within 10% of the original tyre size of 195/60 x 15 and the TEST (recommended) rim size for 245/45 x 16 is 8 inches, so my call is the wheels to have are 16 x 8 all round if possible.
My road wheels are 16 x 8 rear and 16 x 7 front using 225/50 rear and 205/55 front.
My track wheels are custom modified BBS Lorinzer wheels of 16 x 8 all round with 245/45 x 16 tyres.
For the strip (drags) I have a pair of Mickey Thompson ET Drag Radials 265/50 x 16 and the recommended wheel for these is also 8 inches wide.
Looking at DrJosh's pics, I'm suggesting the tyres on his wheels are about 225 wide, due to the excessive stretch on the side walls. Stretch like this on a road car does nothing more than expose the side walls to infinite amounts of damage from an infinite range of sources.
Make up your own mind, but staying within 10% of original, which is mandatory in NSW, any 17", 18" or bigger rim will use a narrower tyre and similarly down to original 15's.
JMHO
These are my wheels collection:
The 5 star wheels are Monza Racing Rims and I use them for street use. The dark silver are the BBS Lorinzer wheels I use for track and the Silver Advans I just recently sourced to use as drag rims.
so 16x8 seems the go. What sort of offset??
i drove the HR around with 17" x 8" +22 on the rear and they were a good fit. i've just bought a set of 18" x 8.5" +20 and when they arrive i'll wack them on the HR and take some pics.
    • Seeing as it's an 04 model, I would be hitting up wreckers first.
    • No not yet.  Hopefully this weekend if I can pluck up the confidence!  I had to sit in the car at one point yesterday to unbolt the rear struts.  As mentioned in an earlier post when I was putting it together there is still a bit of rotation possible so when I sat in the car, it rotated a little bit.  I near shit myself thinking the whole thing was coming down!  I do 99% of my own shit in the shed but I think I might call on some assistance the first time I spin it!
    • Strong first post. On a Skyline-centric forum. Have you considered actually going out into the world, visiting the actual dealership, and asking the parts guy over the counter? Or at least just call them up on the phone?
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
