Im not really sure what detonation or pinking is supposed to sound like...but all i know is that when it occurs it makes a loud "tick tick tick" or "knock knock knock" sound...
Today ive been kind of thrashing my car during quite a hot weather on about 10.8 psi...After i brought it in to a garage for cooling i just opened the bonnet, and it gave out a "tick" sound but it wasn't constant, then a minute later it gave another "tick" sound coming from the turbo side of the engine i THINK?? Then later it didn't happen again but im just worried thinking maybe its just the start of my turbo detonating or maybe because its just a hot weather its making those sounds...
When det/pink does occur, will it happen constantly? and when it does will it only give out sound when turbo is at boost? or does it also occur at vaccum (car stationary)?
What do u guys think?
https://www.sau.com.au/forums/topic/190033-is-this-considered-detonation/
heheh pinging aye? i just got confused cuz whenever i said pinging before some told me its PINKING then when i say pinking some say its pinging so i get confused...so i use detonating now :)
Anyway it ticked whilst the engine was ON not off by the way, if that changes anything?
Edited by R33Turbo
the ticking is just exhaust/engine heat like dan said, and will happen when hot, cold, on or off. it's completely normal. :)
engine pinging/detonation/knock will mainly only happen at high revs when the air/fuel ratio isn't smooth. beleive me, you'll know when your engine starts pinging!
If you popped the bonnet in the gargage - it wont be detonating mate, your motor would be dead if that was the case in the gargage
You'll only find this occurs under load, or if a fuel pump dies in which case it wont last long anyhow and stall.
I bet you have a dead manifold gasket. Nothing more.
Common problem, go see your mechanic to get it fixed
what type of ticking noise? cuz the engine itself makes all sorts of noises close to ticking as well....
Is this ticking noise loud or weak? is it metallic? can i get an example like "clock ticking" or something?
thanks so much i appreciate it....
Mate i honestly think your better off visiting a mechanic that deals with Skylines.
Get him to show you in person so you know for the future.
What something sounds like to one person, might not mean the same to another
cheers
Thanks Nismoid i appreciate your help anywayz... Im happy its not the ping, and also im pretty sure it ain't the gasket cuz i just took it for a drive and it didn't seem to lose any power at all (cuz i thought u lose power when the gaskets blown)...Also i turned the engine on and it gives out a "tick" (sound like when a sheet of metal bends, then bends back the original shape), and even after i just took it for a drive it gave it...But the gasket blowing im assuming should be constant "ticking" sound from that area under the bonnet???
    • Well, in the same way that you can't tell any SUV from any manufacturer in any size category from any other one, "sports" coupes now all look identical. Stand back and squint your eyes and the Supra and the 400Z and the GR/BRZ things all look the same. I was just thinking last night, when sitting behind a Subaru CrossTrek, that I have no idea what it is, how it differs from an XV, or a Forester, or an Outback, or anything else Subaru offer, and I couldn't tell if it was supposed to be small, medium or large. I contrasted that to the good old days, where a HQ Kingswood had familial similarities to an LJ Torana, but there is no way that you could confuse them, and how a bit later, the HX Kinger and the concurrent Torana and the Gemini all had familial similarities, but you still could not confuse them. Ditto the ugly Fords and Chryslers of the era. But now, a RAV4 looks like a Kluger, looks like a Yaris/Cross/whatever they're calling those stupid f**king things, looks like every other Toyota that's not a Camry/Corolla sedan.
    • The Prelude doesn't look that bad without all that lens distortion in those pics. Makes it look disproportionate when it isn't. Actually I kind of liked it at the Osaka Auto Messe earlier this year.
    • Pour in the highest octane, non-ethanol fuel you can get and see if the readout changes. If it's dead bang on 11% then I would question the sensor. Another quick test, just take it out and run normal (in an american accent) gas-o-line through it and see if the sampled ethanol or lack of changes.   United E85 here in the land of drop bears does vary a bit, I've had as high as E87 (could be water in their tanks too, who knows)
    • Yep. And if you ever do, you'll just have to deal with it then.
    • E10 is pretty tightly regulated in percentage. Too much and engines can't adapt. Every incentive is against them to have too little ethanol though. The more ethanol the higher the octane.
