Just Jap Split Dump/front Pipe
R33 S2
 Share
hey guys!
just recently installed a just jap dump/front pipe! some sort of a metal line resting on the top of it where it bolts up. whats this line for and is going 2 hurt touching the dump/front pipe?
thanks in advance
steve
Pics will help...
But offhand Id say its probably a heater/aircon hose.
PM siddr20 - he had the same problem (with a different split dump, not JJ) and actually had it burn a hole through the air con hose!! Not what you want happening obviously!!
i'd imagine its the aircon hose
you will put a hole in it very wuickly if its touching the dump pipe.. get your aircon line modified or bent if you can
i fitted my jj front dump about a month ago and noticed this line was touching, its just an aircon line and can be easily bent out of the way. it gave me a couple of cms clearance. all has been good since installing.
just bend it out of the way... gently of course :(
hey guys!
thanks in advance
steve
aircon hose
if your a n00b like me, and leave it.....ud have no aircon for the summer (which is what im going through now) :rolleyes:
as the others said, u can bend it a bit to get it out of the way....
aircon hose
if your a n00b like me, and leave it.....ud have no aircon for the summer (which is what im going through now) :)
looks like i better be bending it then. i need my aircon ;)
 Share
