Updated price, $150 pickup for a Jap brand catback exhaust with a stainless cannon muffler AND interchangable twin pipe attachment . This is a bargain people!
Whats the catch? You have to pick up the muffler from my place, and the exhaust itself from my dad's place. Not to worry though, as the 2 properties are only about 10 minutes drive from each other in the northern suburbs.
3" Cat Back RS*R Exhaust
Straight through design, very high flowing. Comes with both a stainless RS*R Cannon rear muffler & Stainless Twin Pipe rear attachment which can easily be interchanged. Rest of the exhaust is mild steel. Excellent condition
$150 firm pickup.
Custom silver R33 dash facia
SOLD!
2x 15mm JJR Spacers to suit R33 GTST and other models (5 x 114.3)
SOLD!
Drift Brand Oil Catch Can
SOLD!
Stock S2 Turbo
SOLD!
3" High Flow Cat
SOLD!
10" Kenwood Sub, in ported Box + 220W Ultimate Sound Amp
SOLD!
Edited by Ionos
Can you post to brisbane? And how much?
Would prefer a local sale but if no takers, I can do that. Postage is $30 according to the Aust Post website, the dash facia is the killer because of it's size.
Will update with pictures of all items tonight.
Able to give you a picture of rear muffler and twin pipe tonight, however rest of exhaust is stored at my dad's place until the weekend so no pics until then. (it's just a 3" pipe with a few bends in it and an RS*R stamp/plate).
Hey mate, where in adelaide r u at? also is 150 the cheapest ull go?
Open to reasonable offers - would like to clear some of this stuff out this weekend.
I've got a heap of PM's asking to post items, sorry guys but pickup only for now. I'll update the thread if postage becomes an option.
Pics of stainless twin pipe attachment. Currently fitted with a spark plug if that's your thing, otherwise can just be removed. :P
Needs a bit of a clean but otherwise good knick.
  • 3 weeks later...
  • 3 weeks later...
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
