Hi All,
As the topic says im in dire need of an RB25 turbo coolant line, the one that attached to the turbo, closest to the engine block and manifold. Im in the middle of fitting the turbo to my car and didnt realise i had only the coolant line that runs from the outermost side of the turbo and not the second line.
If anyone has one lying around im looking to get hold of it today if possible, so PM me and if i will come round and pick it up today!! Ill be checking my inbox fairly regularly in the next day or so to make sure i dont miss anyone.
Cheers
Laine
Hi mate, I have a set (coolant inlet and outlet) here if you want them. Can't really separate, but I will have a look and see if I have a spare one of not (have done a couple of turbo installs).
If I don't have a spare the pair will cost you $150 (including banjo bolts and washers).
If I just have a spare of the one you need it will be $75.
Ring me on 0414 904 451 if you want them, as I probably won't check the forums again today. In am in Northgate.
Andrew
