Hi guys need some help. my engine warning light was on for about five minutes today and it has me really worried.
I have a 1998 R34 GTT it has done about 98 and a half thousand k's and have had no trouble with it what so ever.
from what i can tell all the oils and coolants are at max and it never heats up over half way.
Runs great and cant work out what would cause it to com on. has me a bit worried because i just had the valve body
Sent off to mv automatics and had a new shift kit done which im really happy with. Only thing is a couple of days after i got
it done i realised the engine light was on for a little while longer than it should be. do you think it has done something
to my motor? i was also thinking maybe it has some thing to do with the fact that im almost at 100,000 k's i know some cars
are programmed 2 have the light on 2 remind you to get a service.
any help would be really, really appreciated
lee.
https://www.sau.com.au/forums/topic/190094-engine-warning-light/
I've seen the same problem in mates r34. Best thing is to get it checked out by the mechanics. Although i heard that it could be a number of things depending on how long the light is on? Whether it is intermittent? how many flashes etc
did the car feel like it lost any power at all? do u have an aftermarket exhaust? if u do did the sound of the exhaust change????
possibly could be a coilpack as well, just depends, really cause the coilpacks are known to go in the 34's - i should know i lost 3 in 6 months!!!!!!!!!!!
but defintley get the ecu hooked up to find the error code.
im not sure what light comes on in skylines.....but often if your O2 is failing it will come on..... yer as they said...just take it to nissan....they plug it into their computer thing....and it will come up with a fault code....better not to take it to a private mechanic, coz they rnt goin to have the nissan program
Edited by ArNoLdNuMbA5
thanks guys.
no have had no loss of power, and got a stock exhaust.
I called Nissan and they sed they cant help me because its an import and cant do anything about it.
so im going 2 take it 2 Sik Em Wrex on monday after work. Tim thinks its most prob nothing to serious
just a lose wire or a dicky sensor maybe (i bloody hope).
lee.
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to moth things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
    • Editting as I hit post to soon, and this will lock out otherwise.
    • Think ill be going hunting for bad earths and might just replace the alternator for shits n gigs as its an LS alternator but only about 5 years old with very minimal use in that 5 years.
