you rock flick, thanks heaps.
And thats pretty damn cheap. IF only i could put a tow bar on a R34.
Now i need to decide what car i want to tow with. Stagea would be nice but the fuel economy is not really good enough.
Edited by kralster
Of course you can put a tow bar on an R34 Karl - you can put one on any car. Just takes a small amount of fabrication. But I know what people say about towing with turbo cars, full stop, as you put such a load on the turbo, which obviously is not good for it.
I've heard it's very hard to do on the R34, as there is nowhere good to mount it. Seems strange to me seeing as the skyline is a family car in some models.
And you can get a towbar factory option for the S15.
Maybe some suggestions for cars i should look at. I've had a look at a few liberty's but i think they are too expensive for what you get.
Also been looking at falcon utes, but i might as well get a falcon stationwagon seeing as i need a trailer.
Stagea would be great but i don't feel like paying 1500+ insurance per motorbike and car every year.
Nah. So long as you're sensible it won't be on boost all the time and be A-OK.
i.e. Don't tow too heavy and don't try and maintain freeway speeds with something like a furniture trailer (large area so lots of wind resistance).
what sort of trailer are you going to tow?
you have to look at weights etc, then whether you need electric brakes on the trailer (and electronic brake controller in the car). I chose a ute purely because the towing capacity is up from that of a station wagon (substantially up, as theres less metal, making the towing car itself lighter
^^^Swish
just need it to tow a motorbike to and fro racetracks.
I am considering a BA ute i really like them.
So they tow good?
Mate used to tow his and his brother's dirt bikes behind his R32 with a homemade tow kit so if the humble RB20DET can do it the 25 will shit it in.
i have towed with an RB20............and it wasnt the most fun with heavier loads, but that was mainly when it was auto and the loads were heavy (ie another car)
motorbike would be fine behind ya 34. Go speak to Allin Towbars at Richmond, as they'll be able to help ya out, especially with removable tongues etc
Nice car, but if i ever spend that much on a car again it will be another skyline for sure.
I'm pretty made up on the idea for a BA or BF ute.
Yeh dude, Go the Ford ute, We tow the race car with a BA XR8, thing did it soooooo easy to Sandown in Melb and i drove the whole way and back! Highly recommend them!
Speak to Whiplash, Se if he can hook you up a deal at his Ford joint!!
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
