you rock flick, thanks heaps.
And thats pretty damn cheap. IF only i could put a tow bar on a R34.
Now i need to decide what car i want to tow with. Stagea would be nice but the fuel economy is not really good enough.
Edited by kralster
Of course you can put a tow bar on an R34 Karl - you can put one on any car. Just takes a small amount of fabrication. But I know what people say about towing with turbo cars, full stop, as you put such a load on the turbo, which obviously is not good for it.
I've heard it's very hard to do on the R34, as there is nowhere good to mount it. Seems strange to me seeing as the skyline is a family car in some models.
And you can get a towbar factory option for the S15.
Maybe some suggestions for cars i should look at. I've had a look at a few liberty's but i think they are too expensive for what you get.
Also been looking at falcon utes, but i might as well get a falcon stationwagon seeing as i need a trailer.
Stagea would be great but i don't feel like paying 1500+ insurance per motorbike and car every year.
Nah. So long as you're sensible it won't be on boost all the time and be A-OK.
i.e. Don't tow too heavy and don't try and maintain freeway speeds with something like a furniture trailer (large area so lots of wind resistance).
what sort of trailer are you going to tow?
you have to look at weights etc, then whether you need electric brakes on the trailer (and electronic brake controller in the car). I chose a ute purely because the towing capacity is up from that of a station wagon (substantially up, as theres less metal, making the towing car itself lighter
^^^Swish
just need it to tow a motorbike to and fro racetracks.
I am considering a BA ute i really like them.
So they tow good?
Mate used to tow his and his brother's dirt bikes behind his R32 with a homemade tow kit so if the humble RB20DET can do it the 25 will shit it in.
i have towed with an RB20............and it wasnt the most fun with heavier loads, but that was mainly when it was auto and the loads were heavy (ie another car)
motorbike would be fine behind ya 34. Go speak to Allin Towbars at Richmond, as they'll be able to help ya out, especially with removable tongues etc
Nice car, but if i ever spend that much on a car again it will be another skyline for sure.
I'm pretty made up on the idea for a BA or BF ute.
Yeh dude, Go the Ford ute, We tow the race car with a BA XR8, thing did it soooooo easy to Sandown in Melb and i drove the whole way and back! Highly recommend them!
Speak to Whiplash, Se if he can hook you up a deal at his Ford joint!!
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
