Make: Nissan Skyline
Model:R32 GTR
Milage:92,000
Colour:Gunmetal Grey
Currently registered?YES
Price: $29,500ono
Contact: Jeremy 0414879711
POWER
419AWKW @25psi TUNED BY TM AUTOSPORTS at Tuggerah 43530733
Wheel spun 1st gear and ran 10.989 @ 130mph on street tyres with all interior + sound system in car minus spare wheel.
see bottom of page for video. only ever had 6 drag runs, never been on curcuit or drifted
ENGINE rebuilt 10,000ks ago with new bearings put in 3000ks ago when fitted tomei oil pump
(i have never killed any bearings, when i first built the engine i didnt know about the common rb26 oil problems. so i pulled the crank out and put on a JUN collar and Tomei oil pump (upgrading from the N1 pump i had on it) fitted an oil restrictor and external oil return, and i thought for the sake of 150 dollars i put some new bearings in. every one has been worried that the engine might have failed. which it hasnt.
Call me if you want to discuss 0414879711
cheers
Jez )
RB26DET APEXi power fc
Garret T04Z AR .70 front AR 1.0 rear running 25psi
50mm external wastegate both on custom manifold all PRO COAT ceramic coated
engine 40 thou over size
JE pistons, prepped rods and crank all balanced
ACL race bearings
Tomei Metal headgasket 1.2mm and metal manifold gaskets
ARP rod bolts, head stud kit
Tomei Oil Pump (the unbreakable one) with external oil return from back of head to sump
Tomei Sump Baffle, 1.5mm oil restrictor
N1 water pump
tomei poncams 260 9.15
800cc SARD injectors
3.5inch APEXi exhaust with magic catalytic converter
044 pump with sard fuel pressure regulator
oil filter relocator kit
split fire coils
hybrid 3 stage boost controller
RUNNING GEAR
Os Giken twin plate clutch
New front diff
New rear diff
DIRTGARAGE 2 wheel drive/4 wheel drive switch plus Attesa controller
Hicas Lock bar and all 4wsteer gear removed
CUSCO coil overs fully adjustable
rear camber adjusters
INTERIOR
stock 32GTR interior in excellent condition
Pioneer headunit, front and rear speakers running off Pioneer amplifier
Nismo boost gauge and air/fuel gauge
EXTERIOR
Excellent condition, standard paint job with 2 small dents (front left guard and rear right guard) which were there when i imported it.
one thing wrong with outside of car is front lip missing.
This car does not attract police hence the number plates (DVS32R) DEVIOUS 32R
please call me if you want to arrange a meet,
please do not call me if you want to joy ride.
Cheers Jeremy
10 SECOND VIDEO
CLICKY CLICKY my car is the grey one, XCALABA is on the right and blows 1 of his turbos near the finish :P
Edited by DVS32R
https://www.sau.com.au/forums/topic/190122-419awkw-10-second-street-r32-gtr/
I've seen probably every run this car has done and it's absolutely fantastic to watch and goes like a rocket on a relatively road setup.
thanks benm,
dyno sheet will be posted up tonight with some pics of car.
free bump... i dont like your chances gettin in the 30s for it but wish you all the best
thanks mate, im starting to think the same thing.
NEW PRICE $30,000
call me if your interested, 0414879711
need it gone picking up new car next week.
Lots and Lots of money put into this car,
comes with spare parts such as stock GTR wheels in white, heaps of stock parts if you want them with car, also N1 oil pump,
gl with the sale, would have been mine if it were selling 6 months ago..
Sorry to track off the subject, is there any chance you have a photo of th stock wheels in white?
Car Still for Sale.
car is at oldies place in garage cause i got my new car now in mine,
when i go there next i will take a photo of stock wheels in white, suits it quite well cept for the fact they look so small
I may have missed this above, but just a few questions....
What Year is the car?
What crank are you using?
What block are you using?
What brakes are on the car?
Any work done to the Gearbox?
I'm looking for a circuit car, and trying to minimise any additional purchases...
Edited by TwinTurboCelica
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
