Forsale is an as new gcg ball bearing hiflow turbo for an r33gtst. This will bolt straight onto standard manifold and includes all lines and a heavyduty xtr actuator. Turbo has seen only approx 4000klms and has no shaft play at all and turbo still looks brand new
looking for $1500 ono
located in the sutherland shire nsw.
pm if interested
Edited by robbo33
https://www.sau.com.au/forums/topic/190126-as-new-gcg-hiflow-for-r33gtst/
mitch this turbo is capable of pushing around 260-280kw easily.
Friend had it on his and i have driven it (same turbo as this guy is selling) and man it pulls hard!!
wish i had the money otherwise i would have bought this turbo.. but no job :blush:
yeah sidd ive heard some lucky people pull around 260-280kw
but than some people having like 230kw at 16psi?
need to justify if its worth the money to push around 260-280 like u said cause i would be mega pissed if i brought somthin like this, forked out cash for 550cc injectors z32 and only got like 25rwkw more than what i have now
mitch, it comes down to the tuner.. trust me
Get it tuned same place you got yours tuned at, and it will easily reach 260..
So jealous tho.. wish i could afford a hi-flow..
to much for a highflow mate. u can buy a 3040 or 3675r for that price
Hi newbie, you should learn to keep your opinion to yourself, what he is asking is about average price, comments like that will get you banned.
yeh mate thats if you want 350rwkw and then you pay for water and oil lines, cooler mods because the turbo is so big and a new manifold.
this is a complete bolt on ballbearing hiflow, good for 250rwkws. it cost $1950 brand new. this is $1400 and you can sell your orignal turbo so really its only about $1100
hey guys im kinda interested. ive heard for the same boost these highflows will make more power than a stock turbo. so if i were to run this turbo at 10psi, would my r34smic be sufficient to cool? what's the highest boost i could run b4 the cooler holds me back?
no not the same turbo. that was a garrett turbo that had been hiflowed by gcg.
this one is a stock r33 gtst turbo hiflowed by gcg. they have different serial and part numbers
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
