Forsale is an as new gcg ball bearing hiflow turbo for an r33gtst. This will bolt straight onto standard manifold and includes all lines and a heavyduty xtr actuator. Turbo has seen only approx 4000klms and has no shaft play at all and turbo still looks brand new
looking for $1500 ono
located in the sutherland shire nsw.
pm if interested
Edited by robbo33
https://www.sau.com.au/forums/topic/190126-as-new-gcg-hiflow-for-r33gtst/
mitch this turbo is capable of pushing around 260-280kw easily.
Friend had it on his and i have driven it (same turbo as this guy is selling) and man it pulls hard!!
wish i had the money otherwise i would have bought this turbo.. but no job :blush:
yeah sidd ive heard some lucky people pull around 260-280kw
but than some people having like 230kw at 16psi?
need to justify if its worth the money to push around 260-280 like u said cause i would be mega pissed if i brought somthin like this, forked out cash for 550cc injectors z32 and only got like 25rwkw more than what i have now
mitch, it comes down to the tuner.. trust me
Get it tuned same place you got yours tuned at, and it will easily reach 260..
So jealous tho.. wish i could afford a hi-flow..
to much for a highflow mate. u can buy a 3040 or 3675r for that price
Hi newbie, you should learn to keep your opinion to yourself, what he is asking is about average price, comments like that will get you banned.
yeh mate thats if you want 350rwkw and then you pay for water and oil lines, cooler mods because the turbo is so big and a new manifold.
this is a complete bolt on ballbearing hiflow, good for 250rwkws. it cost $1950 brand new. this is $1400 and you can sell your orignal turbo so really its only about $1100
hey guys im kinda interested. ive heard for the same boost these highflows will make more power than a stock turbo. so if i were to run this turbo at 10psi, would my r34smic be sufficient to cool? what's the highest boost i could run b4 the cooler holds me back?
no not the same turbo. that was a garrett turbo that had been hiflowed by gcg.
this one is a stock r33 gtst turbo hiflowed by gcg. they have different serial and part numbers
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
