Originally posted by bbenny
hey price is about $19.50ea
I dont know what u should gap them too. i know for turbo RB engines its 0.8mm but on the packet the iridiums say not to change the gap because the tips are very fine and fragile.
I gapped them to 0.8 anyway and they have been pretty good.
By gapping expensive iridium spark plugs, as far as i know, voids the purpose of getting expensive iridium spark plugs, as what you pay for is the coating, which is removed when you gap them.
I may be wrong....
  • Replies 44
well i gaped them by tapping the top of the bent curve without fitting anything in between just to make sure no surfaces were scratched, so there was no chance of the coating being removed. i then just used a feeler guage to check gap distance.
Worked perfect, much better than the platinums. so im sure its not a problem as long as you are careful.
Iridiums are gapped at 1.1 by default. I am using them at 1 bar boost and have absolutely no problems, the mixture is perfect and there are no flat spots or anything, so I'm not sure why you'd need to regap them when running any normal sort of boost. Maybe with even higher boost you might need to gap them a bit smaller, I don't know.
Ths only platinums I've used are the old ones that were in the car when I got it, so I can't really say if the Iridiums are "better". But everyone seems to need to re-gap their platinums, so for not having to re-gap the iridiums makes them seem worth the extra couple of bucks to me. Not for the time/effort saved, but the fact that you can have a more universal gap (ie just forget about it).
  • 1 month later...
akeenan: in your great wisdom, can you tell my why my NGK coppers melted? I think that Coppers are only asking for trouble after the latest stint..... All of the plugs were stuffed (the little finger was melted off ever single one). I think after that I can justify the price of iridiums
Sumo
I have to correct myself about the Iridiums gap too. I'd been told that it was 1.1mm. I decided to expierment with changing the gap awhile ago to help eliminate flat spots. I pulled the first plug out and checked the gap, and it was 0.7mm. Oh well, nothing more to do there :)
the only ngk plugs specified for a r33 gtr are platinum or iridium no copper ( i'm sure u can find copper though but wouldnt last )and the diff in price is only $2 , iridiums last a bit longer , i dont know that they are any better though .
Sumo
no i cannot tell you why they melted. sorry..
Running lean or detonation is the main cause of plugs melting isn't it? If so, maybe copper plugs would serve as a good warning device. Better a melted plug than a melted piston!
I am under the impression that the new technology plugs come set at the right gap for the application. Correct me if I'm wrong, but setting the gap in sparkplugs was dome in the low-tech days when the electrode wore away much more than it does with electronic controlled ingnition systems.
what heat range would be best for RB25DET? I was told heat range 6 is good, but some ppl here uses heat range 7??
At what boost level you should use 6 and 7?
And someone also told me the suitable gaps is 0.8mm ?
using platinum or iridum they can have a very fine tip witch produces a better spark . u can have a fine tip with standard nickel but the life expectancy would be very short thats the reason the nickel tips are much bigger ( longer life )the platinum on the tip doesnt burn as easy so it lasts much longerand iridium longer still ( they claim iridium give a better spark as well .
i wouldnt use nickel on any of my cars , i only use platinum but next time i'll try iridium as they are only $2 more .
there are 2 types of iridium ngk sparkies....
the difference is in the centre electrode (tip) size.. 0.8mm and 0.6mm.
0.8 is the same size as plats so they are only better by lasting longer.
0.6mm one has better spark and uses less voltage but only lasts same distance as the platinum ones. also when you order em make sure u tell em to get the model without the -11 at end cause then they will come gapped to .8mm not sure the code for the RB's. you dont want to gap them the traditional way cause you might scratch off the iri coating which defies the getting em in first place!
i used to use the v-groove copper ones but with the iridium's engine does feel smoother and seems to hold boost better.
just put platinums in mine and noticed a slight improvement. dont know if the iridium ones would make much difference. a few guys i know have said that they didnt notice any difference between platinums and iridiums. they will probably just last longer.
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
