hey guys
selling my coilovers as ive sold my car...
no leaks knocks or noises
these things are immaculate and are by far the best coilovers ive ever had!
Denzo has used the same model of coilover in the past and James Vahoumis currently uses them
the fronts do have s14/s15 bottoms on them as this is how they were ordered brand new as i was using s14 uprights in my cefiro... so these are perfect for any s13/180/c33/a31 owner who has done a 5 stud conversion with s14/r33/stagea uprights...
you can still use the fronts with factory uprights - you just need to drill your uprights out 2mm as this is the difference in size of the upright mounts
8 way dampeners - none of this wanky 32 or 56 way crap
10kg front springs progressive rate
8kg rear springs progressive rate
pillowball rear tops and camber tops at the front
$2000 $1950 $1850 shipped aus wide
    • Just buy a BMW if you want that... You can then choose whatever engine of theirs you want 😛
    • Clear vinyl wrap or clear coat?
    • There really needs to be an ODBII item that can play intake noise through speakers, synchronized with your current RPM and TPS%.
    • Worth most of the $50k alone!
    • So, we now have a straight and clean boot lid inbound and the car goes in for paint, again, on Wednesday, and will be ready on Friday, all ready to get cams and stuff on Monday  And by straight and clean.....I mean a brand new OEM one that cost..... $1300....😪 Sadly there's no clean undamaged used soft top version available, plenty for the power retractable hard top versions though, which is arse and makes Mark have the sads I could have waited longer, until a NC sort top boot lid eventually turned up, but I'm sick of waiting and said fark it and made it rain cash, meh In other naturally aspirated news, one of the guys at work brought in his old Corola which had a 4AGE in it, really nice clean car with lots of mods, including ITB's, man that things induction noise sounds sick with all of the dorts that makes you smile......maybe the NC needs ITB's, yeah, basically for the noise they make, but they're pretty expensive, but, they sound so damn good I may bring this up when I drop the car up on Monday, and by may, I mean I will🤣🤑🤪🤣
