hi all,
i was just wondering about some RB engines i have seen around.
some of them have the 6 coilpacks replaced with high tension leads running to the spark plugs instead.
has the ignition module and the coil been replaced with aftermarket units? or how is this done?
any advantages other than easier to change the plugs?
can someone please advise.
ron
https://www.sau.com.au/forums/topic/19017-new-ignition-setup/
believe this is done to allow bigger coilpacks, therefore bigger spark. Very handy if you are running CDI.
Have only seen it done on a track GTR, it was using 6 ford 6 cylinder coil packs, ie, each coilpack was used by ford on the falcons to run six sparkplugs, was hooked up to its own plug.
I have been told that just by removing the cover on the stock coilpacks will aid cooling as well (of the coilpacks)
ive seen this done using the factory coils bolted to the firewall runnin ht leads to the spark plugs ona factory computer
but i dont think u can use the bosh gt40 coils with the factory igtion system coz the gt40 coils have 2 wires + and - were as the factory system has 3 wires + and - and a signal wire tryin to find out what the signal wire does at the moment
hi,
what steve said earlier sounds right by using some Ford coils to replace. I had a look in an MSD catalog and found some modules that may work for 6 cly of course, but dunno about the cost.
i took my cover off a while a go but cannot tell any different.
but it will sure cool the packs down.
the car that i saw was stock by the way, man!!! should ve had a better look!!!!
ron
Hi guys, if you are loking at more than 750 bhp then upgrading the standard coils may be worthwhile, under that it's a waste of money.
If you are looking at more than 750 bhp, then 6 individual coil packs suitable for CDI would be the best choice. No hi tension leads as they add another area for problems. On the Motec CDI equiped race cars we use Mercury outboard coils at the plugs mounted on a fabricated rail.
Hope that helps
When you look at the age of coil packs on a R32 in particular, we need to start thinking about alternative and newer methods to ensure reliability of the vehicle if we decide to own it for a few more years.
Another benefit is the ease of changing plugs. I hate that job and im sure there are other out there that do to.
I have thought about getting my hands on a crow cams amplifier pack and wiring it into the loom so it recieves the signal from the ignition pack then power is transferred to the plugs through hi tension leads?
Not really interested in adding hi tension leads but would be keen to find a cheaper replacement for when the coils die.
I guess you could resite the coil rails to mount on the rocker cover and run very short plug leads
These cars you see running aftermarket coils are using aftermarket ECU's.
Around 1 year ago, I saw an RB with I think it was a VP coil pack running high tension leads.
A few phone calls later and I was told that it is impossible with the stock ECU.
The standard coils are good enough for around 700hp so replacing them is a waste of time and money, heat soak is what kills them a CDI is a good fix for this problem as the dwell is reduced resulting in a decrease in coil heating. The standard coils have 3 wires running to them 1 pos 1 neg and the other is a ground connection to the cyl head.
cheers
Hi guys, the standard RB ignition coils are not really designed for use with a CDI. A CDI works by repeated rapid discharges from a capacitor during a single plug firing. The standard RB coils are designed for one single discharge per firing.
So if you intend to drive the coils with a CDI, then you really should use coils designed for multiple discharges. Otherwise you are not going to see the best effect from using a CDI. The cheapest/best CDI capable coils we have found are the Mercury outboard coils I previously mentioned.
Realistically I have found a very, very low percentage of RB standard coil failures. Plus good second hand ones have proven very easy and cheap to locate. High tension lead failure is a far more likely occurrence, so I avoid them. As Mort posted, over 700 bhp and I would think seriously about CDI with on plug coils, under that and its a waste of time and money.
Hope that clarifies
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
