Wrecking R33 Gts-t '97 Model-offer To Sa First
As per other thread I am wrecking an R33 gts-t '97 series II White, 70,000km front end damage, offering to SA ppl first. A;; items will be in very good condition unless stated otherwise, all bolts/nuts etc included with individual parts.
Thought I'd post it here rather than in the sticky for sale as it would clog that thread up, happy to move post elsewhere if the moderators want me too.
Link to all pics labelled and in here---> http://s127.photobucket.com/albums/p148/PT15/
(if no pic found then you should know what it looks like already)
Entire boot lining (including floor and wooden piece) $100
Tail lights with globes/wiring $200pair ($150 each)
Rear centre garnish (says SKYLINE) $75
Boot sound deadener $40
Rubber seals for door shell L&R $80 ($50 each)
Rubber seal for boot shell $40
Weather strips L&R with all clips $50
Climate control unit $80
Cluster/odometer (showing 70,036km) $100
Cluster plastic surround $40
Glovebox complete $50
Dashboard with top vents undamaged (as per pic) $150
Centre console $50
Stereo/gearboot surround $50
Plastic door piece (says "SKYLINE") $80pair
Roof lining $80
Cabin carpet $100
Sunvisors $30 pair ($20 each)
Rear vision mirror $20
Interior lights both $30 ($20 each)
All interior surround plastics with x3 grab handles $150
Rear parcel shelf with speaker covers $80
Front seats $250 pair (passenger x1 small cigarette burn)
Rear seats $100
Seat belts with brackets/bolts $200 the lot x5 (or $100 front/$100 rear)
Rear reo bar (undamaged) $120
Boot with adjustable spoiler (see pics) $250 complete with gas struts etc (spoiler alone $200)
Rear bar few light scratches (no cracks or dents) $150
Rear pods $50 pair
Side skirts (L damaged bracket at back, R damaged at front...see pics) $50 pair
Rear wiper $20
Rad and A/C clamps $20 all 4
Horns x2 with wiring $30
Greddy M-spec cold pipes for FMIC (only cold side) $80
Turbosmart Type I BOV with R33 adaptor $100 (with boxes and instructions etc)
Greddy turbo timer silver (in box with all wiring/instructions) $100
Gizzmo EBC with manuals/wiring etc $150
Viper alarm (?1000 model??), complete with all wiring and x2 remotes $150
Jap cat-back exhaust (appears 3" to 3.5 or 4" haven't measured it) $350
Razo shift knob $50
Greddy water spray bottle $75
Speco boost guage (mechanical with cup holder, silver 52mm, reads to 30psi) $75
Anything else not listed is on the car still and not yet available, other thread has list of damaged/unavailable parts on page 2
ill take the cluster m8. pm your number or call me on 0404 232 231 cheers clayton
Vu you cant put dibs on the spoiler as i have already said i wanted it in the other thread
oops sorry about double post, Vu we can discuss things later if you come online and see this try and ring me my number is in my profile
Price for passenger side door only - no glass or trim required. What is the paint code?
still on the car, will sell with no trim and may remove window, don't know price yet, factory R33 Series II White, no dents but there is a chip the size of a 20cent piece on it
pics of pods coming...probably on Thursday
Edited by PT
does yours have any holes or any thing on it? coz i want another one to replace the one ive got now coz ive got a hole in mine coz the boost gauge was bolted there.
how's $30 sound, assume you mean the A-pillar (some have boost guages attached etc)
not too sure will get back to you
do you have the A pillar with the gauge holders?
no
How much for the drivers side front window? Also, if the bootlid is not taken, how much for that?
bootlid/spoiler combo is already taken
not sure what drivers window is worth?
yeah yeah yeah pics of pods and other pics coming soon, they will be posted up on Thursday (tomorrow) around lunch time.
    • Gosh these Rb pulleys/alternator or whatever is causing the problem is absolute rubbish lol. Haven't even done that many km on it.
    • Yeah man, will only progress further hopefully. The bonnet is coming off to get sprayed very soon
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
