Wrecking R33 Gts-t '97 Model-offer To Sa First
As per other thread I am wrecking an R33 gts-t '97 series II White, 70,000km front end damage, offering to SA ppl first. A;; items will be in very good condition unless stated otherwise, all bolts/nuts etc included with individual parts.
Thought I'd post it here rather than in the sticky for sale as it would clog that thread up, happy to move post elsewhere if the moderators want me too.
Link to all pics labelled and in here---> http://s127.photobucket.com/albums/p148/PT15/
(if no pic found then you should know what it looks like already)
Entire boot lining (including floor and wooden piece) $100
Tail lights with globes/wiring $200pair ($150 each)
Rear centre garnish (says SKYLINE) $75
Boot sound deadener $40
Rubber seals for door shell L&R $80 ($50 each)
Rubber seal for boot shell $40
Weather strips L&R with all clips $50
Climate control unit $80
Cluster/odometer (showing 70,036km) $100
Cluster plastic surround $40
Glovebox complete $50
Dashboard with top vents undamaged (as per pic) $150
Centre console $50
Stereo/gearboot surround $50
Plastic door piece (says "SKYLINE") $80pair
Roof lining $80
Cabin carpet $100
Sunvisors $30 pair ($20 each)
Rear vision mirror $20
Interior lights both $30 ($20 each)
All interior surround plastics with x3 grab handles $150
Rear parcel shelf with speaker covers $80
Front seats $250 pair (passenger x1 small cigarette burn)
Rear seats $100
Seat belts with brackets/bolts $200 the lot x5 (or $100 front/$100 rear)
Rear reo bar (undamaged) $120
Boot with adjustable spoiler (see pics) $250 complete with gas struts etc (spoiler alone $200)
Rear bar few light scratches (no cracks or dents) $150
Rear pods $50 pair
Side skirts (L damaged bracket at back, R damaged at front...see pics) $50 pair
Rear wiper $20
Rad and A/C clamps $20 all 4
Horns x2 with wiring $30
Greddy M-spec cold pipes for FMIC (only cold side) $80
Turbosmart Type I BOV with R33 adaptor $100 (with boxes and instructions etc)
Greddy turbo timer silver (in box with all wiring/instructions) $100
Gizzmo EBC with manuals/wiring etc $150
Viper alarm (?1000 model??), complete with all wiring and x2 remotes $150
Jap cat-back exhaust (appears 3" to 3.5 or 4" haven't measured it) $350
Razo shift knob $50
Greddy water spray bottle $75
Speco boost guage (mechanical with cup holder, silver 52mm, reads to 30psi) $75
Anything else not listed is on the car still and not yet available, other thread has list of damaged/unavailable parts on page 2
ill take the cluster m8. pm your number or call me on 0404 232 231 cheers clayton
Vu you cant put dibs on the spoiler as i have already said i wanted it in the other thread
oops sorry about double post, Vu we can discuss things later if you come online and see this try and ring me my number is in my profile
Price for passenger side door only - no glass or trim required. What is the paint code?
still on the car, will sell with no trim and may remove window, don't know price yet, factory R33 Series II White, no dents but there is a chip the size of a 20cent piece on it
pics of pods coming...probably on Thursday
Edited by PT
does yours have any holes or any thing on it? coz i want another one to replace the one ive got now coz ive got a hole in mine coz the boost gauge was bolted there.
how's $30 sound, assume you mean the A-pillar (some have boost guages attached etc)
not too sure will get back to you
do you have the A pillar with the gauge holders?
no
How much for the drivers side front window? Also, if the bootlid is not taken, how much for that?
bootlid/spoiler combo is already taken
not sure what drivers window is worth?
yeah yeah yeah pics of pods and other pics coming soon, they will be posted up on Thursday (tomorrow) around lunch time.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
