Wrecking R33 Gts-t '97 Model-offer To Sa First
don't think the alarm is "black wire" (to install/remove the wires to from computer to control box need to be cut/soldered to pass it through the firewall....they are then different colours from what's in cabin to what's in the engine bay) hope that makes sense
someone has put an offer on alarm/turbo timer combo for $220 but I'm after $235 if sold as a pair and waiting for his reply
re the 5 stud hubs your right I won't need them, I only need the backing plate etc, just need to buy a 36mm socket to remove the nut holding the hub on
Edited by PT
Do you have the black plastic thing that goes over the boot latch (When you pop the boot and look straight down at the boot latch, that black plastic cover) and how much?
Edited by kalel
I have painstakingly removed the wiring from the car/engine bay (all plugs have been labelled too), engine will be pulled out in 1-2 weeks, I will be selling the engine complete with turbo/alternator/air con compressor/ECU and entire wiring from the whole car (no gearbox/radiator or intercooler though). Not sure what it's worth though, done 70,000km.
manifold heat shielding will be sold with the whole engine
just looked then for you no black plastic cover over the boot latch sorry
ร—
ร—
