  • Replies 41
I think you can just find some decent projectors from wreckers...and some 2nd hand ballast and bulbs, just make sure they're OEM brands..
Just savage them from S2000 and Accord euro (luxury), they are known to be s2k and TSX projectors. S2k is probably one of the best HID projectors out there.
Here's a few pics of the s2000 projectors i'm trying to retrofit..
Edited by R34Ricer
https://www.sau.com.au/forums/topic/190175-hid/page/2/#findComment-3540411
You've got to watch out for the sizes of the projectors as well. S2000 Projectors are one of the biggest you can get. As far as I know, you're best off getting Honda Euro projectors. They're 2.5" or 3" and should fit into the standard projector position fine. They're also called TSX like R34Ricer has mentioned.
https://www.sau.com.au/forums/topic/190175-hid/page/2/#findComment-3541046
  • 4 weeks later...
@adam
i have pair of raybrig bulbs (h3c) in my 32R which didnt improve my lighting one bit.. however now u mention it, it does have two clear hotspots.. is there anyway of getting rid of this (could the bulbs be installed incorrectly).. is there any mechanism on the headlight that allows you to alter the light direction, spread etc
https://www.sau.com.au/forums/topic/190175-hid/page/2/#findComment-3577912
@adam
Hi mate, are these 'raybrig' globes HID globes by any chance? I've never heard of them before.
Hot spots usually occur when you install HID globes because halogen and HID globes produce their 'peak' brightness at different positions along the globe (halogen produce it at the top of the globes, HID produce it in the near middle). The head light housing is designed for the halogen globes, so the reflectors/projectors collect the light from that area most. If you put in HID globes (different brightness position), the reflectors will collect the 'wrong' light. f**k, haha, I didn't exactly explain that all too well, but I hope you can put the information together for a better understanding. :D
As far fixing it up, I don't think you can apart from using globes that the head light housing was designed for.
From my experience, all halogen head lights have some hot spots to an extent. It's just that the light isn't bright enough to produce a 'clear' hot spot.
Cheers :whistling:
https://www.sau.com.au/forums/topic/190175-hid/page/2/#findComment-3578007
For those of you who would like to learn more about HID's in general should give this a read. It's a great read and you'll learn a lot.
I hope this will change everyones minds about installing those cheap HID kits into your halogen designed headlights.
http://www.intellexual.net/hid.html
Enjoy!
https://www.sau.com.au/forums/topic/190175-hid/page/2/#findComment-3578026
@adam.. nope just normal raybrig white bulbs to get rid of the yellow look.. cant say brightness increased nor distance.. if anything the stock lights had better coverage.. still exploring good HID option.. does anyone know if the GTR N1 headlights allow for HID kits as low beam is no longer projector style??
https://www.sau.com.au/forums/topic/190175-hid/page/2/#findComment-3580212
Those HID kits in reflector housings will give worse results than putting them in projectors. You often see people not recommend putting those kits into R33's because they've got reflectors. Having the kits in R32 projectors, you could be forgiven for having them in, but putting them in a reflector is a big 'no no'.
As for the bulb, try getting some philips globes. You'll spend a little more, but you'll also get better results.
Edit: If you want the best headlight output, go retrofit a projector from a car which had HID's as standard. Honda Euro's are a popular choice.
Edited by adam-__-
https://www.sau.com.au/forums/topic/190175-hid/page/2/#findComment-3580748
  • 2 months later...
Bringing up an old thread, does anyone know of any place or anyone that can do a retrofit for me?
I can easily get the parts but sadly I have no clue when it comes to doing something like this. I tried PM-ing Ronin but he doesnt want to go thru it again. If any DIY-er wants to earn some extra cash PM me.
https://www.sau.com.au/forums/topic/190175-hid/page/2/#findComment-3727669
how would the N1 headlights go.. should be able to get better visibility with those right??
If you're talking about standard (no HID in them), they're slightly better then the ones with the projectors. Not worth purchasing for the extra little light though.
https://www.sau.com.au/forums/topic/190175-hid/page/2/#findComment-3753484
are the N1 better option vs std to put HID into as it wont be via projector lense?
Nah, the 'N1' style headlights are reflectors and if you put HID's in them, they'll be worse than putting them in projectors.
Putting them in the projectors will be better, but still shit.
https://www.sau.com.au/forums/topic/190175-hid/page/2/#findComment-3753755
  • 2 months later...
im bak
hehe
so what are the best projectors to use
thanks
Have a read on hidplanet.com. It's not only the projector that makes the cut off line and beam look good. The people over on there use bits and pieces from different cars. Mixing and matching lenses to different shields to different ballasts, etc.
There are some crazy lights over on that site.
https://www.sau.com.au/forums/topic/190175-hid/page/2/#findComment-3903265
yeah, HIDplanet are good
the FX35/45 projectors are cheap, the shrouds are easy to change to RHD for our roads but are a bit blurry in the cutoff line, but you can get accord projector lenses or similar TSX lenses to replace the FX35 lenses if you want a crisp cutoff.
They only cost liek $50 USD off ebay plus shipping
they take D2S bulbs, so you can get an H4 to D2S bulb kit and it'll fit in your old wiring, you can also wire it up to do low/high beam because it has a motor in the housing, so instead of flashing the bulbs off, it pulls the shroud down
I had them fitting in my old skyline lights, they are a 2.5" and fit nicely with a bit of cutting to the back of the headlight, probably takes half an hour to fit them if you hack them up a bit :D
I have since sold mine though, since I'm selling my skylines off, but I'm looking at picking up a Datto 1200 and putting a ca18det into it or rb20, so I'm still floating on these forums, I'll hopefully put custom HID projectors into the old datto headlights for a bit of fun too
https://www.sau.com.au/forums/topic/190175-hid/page/2/#findComment-3905982
I had them fitting in my old skyline lights, they are a 2.5" and fit nicely with a bit of cutting to the back of the headlight, probably takes half an hour to fit them if you hack them up a bit :down:
I've been wondering what you got up to! Do you have any photos of your retrofit at all? I remember seeing a few photos, but did you manage to finish it off?
https://www.sau.com.au/forums/topic/190175-hid/page/2/#findComment-3906500
