I have recently purchased the car of my dreams. Now the only problem is the key doesn't unlock the boot and the lever decided not to work. Is the boot a mechanical or electrical latch set up? If all else fail's ill go to plan b
Has any one had this sort of problem ?
https://www.sau.com.au/forums/topic/190242-boot/
The valet thing he's talking about is a 'mode' you set your boot lock into. You can disconnect your boot lever and the only way of opening the boot is by key. There should be three keys for your car, two 'master' ones which can get into everything and one 'valet' one. This key can't access your boot by the key or glove box.
https://www.sau.com.au/forums/topic/190242-boot/#findComment-3427000
There is one other *possible* way... but it will be an absolute last resort if you can't get the key.
As adam-__- mentioned, there is a 'Valet' lock that you can enable so that the only way you can get into the boot is with one of the non-valet keys. This is a little lever inside the boot itself, where the latch is. This simply disables the mechanism for the cable-operated lever release.
What you *could* do... and i stress this is a last-resort, it's a royal PITA... is remove the rear seat, then there should be a removable panel behid the seat that allows access to the boot... like where the fuel-pump etc is... and then reach through that to release the valet-lock. then you can use the lever inside the car to open the boot. Last resort, but better than destroying the boot latch or whatever. Once you've got it into non-valet mode.. maybe break off the valet switch? :ermm:
Anyway, it's just a suggestion...
Edited by Samon
https://www.sau.com.au/forums/topic/190242-boot/#findComment-3451102
I was thinking this aswell, but that body strengthening plate i believe is only removable on R32's???
Well... it's been a while since I had the rear seat out of my 33... but I'm pretty sure it looked removable. Lots of bolts... but removable.
https://www.sau.com.au/forums/topic/190242-boot/#findComment-3451756
The thing about the keys is correct. I had the same problem, I only had the valet key when I bought my car. From memory the key is only slightly different, but the locksmith I dealt with knew what he was on about, looked up some info on the locks and was able to cut me a key to fit everything. I think it's the same key but part of it is only slightly shorter or longer where the ridge stops the key going in any further into the lock.
https://www.sau.com.au/forums/topic/190242-boot/#findComment-3451832
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 😂😂 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
