Interesting. You may like to try raising the front up. I use 355 front, 345 rear. The more nose down it goes the more it understeers.
Secondly, with regard to camber there are two sorts. Static camber, ie measured at rest & dynamic camber, measured when the thing is loaded up through the corners. However much static camber you car may be running you seem to have insifficient dynamic camber. This is shown in the photos as the front wheel "tucking under" during cornering. Anyway, form what I understand, this is a suspension geometry issue tiedlinked to too low a ride height.
So it would be worth (IMHO) trying the car with an extra 15mm in the front ride height.
Anyway here is mine cornering - note the soft springs (Half your rate) but the front tyre -ve camber is still ok, even though the static is only - 2 degrees. I awill be chucking some harder springs at it today/tomorrow.
Nice car by the way Richard
I would go much less camber than that. Around 3deg front and bit under 2deg rear.
As for dynamic camber, the rate at which it increases really should be greater if the car is lower, so I dont think that's the problem for insufficient camber.
Do you know the actual amount of static camber you have at the moment?
i asked for neg 5 when it was done last.
Car is going back for another alinement next week which i will watch it being done.
I have also been speaking to Bridgstone here and the motorsport guys are going to come back to me with some setting that should work for a heavier car. Lucky as these guys are a sponsor of the track where we race and had done a lot of development in the compound for this tyre.
:-) Also were none to please to hear the pilot cup sport was faster
As far as I know (ok, I don't) you cannot adjust the front camber with the Cusco arms - there is no mechanism.
If you have Bridgestone blokes there then please pummell them with the questions of the day:
Hot set pressures for the RE55's on the Gt-R's & optimal operating temp for the tread face.
Edited by djr81
Ok have a operating temp of 60 degree for the RE 55s hard compound which is the compound used/developed for the very sandy conditions we have here.
pressure will depend on the day i would guess but we are in the low 30's here at the moment so not so far removed from sunny QLD
i will keep you in the loop.
Interesting. I asked because the conditions you have over there are probably pretty similar to what we have in WA come summer. Both temperatures & the amount of sand.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
