SOLD SOLD SOLD
Make: nissan
Model: r33 gtst skyline
Colour: maroon
Price: $12,000 price drop $10000
Contact: MITCH 0410627751
Comments / Modifications: engine was done by boosted extremes had about $13000 spent on engine photos on http://www.boostedxtremes.com.au/. fully rebuilt engine with forged internals, port and polished head with race valves and springs, cams, custom plenum, custom exhaust manifold, gt35r turbo, fuel pressure regulator, custom intercooler piping and fmic, bov, 2 stage boost controler, remapped computer. front bar has been repaired and is in primer.car comes with DRR33 plates
Images: post-42725-1193043527_thumb.jpg post-42725-1193043968_thumb.jpgpost-42725-1193043983_thumb.jpg
Edited by DRR33
https://www.sau.com.au/forums/topic/190279-fs-qld-1993-gtst-r33-10000/
  • Replies 60
Posted Images
hey mate not sure how much power its making but ive been told that its will make 400hp+ atw, going to strip this weekend for qtr mile time, got 5 spoke 17s, body is good but needs paint has been painted by previous owner but needs to be redone, no sunroof, there is more stuff on the car than i said but cant think of it.
Edited by DRR33
car currently running on 10psi will make 300kw atw on this settin but with a good dyno tune and more boost can make a lot more.
your car is making 300rwkw on 10psi with a gt35 turbo?
and can make more with better tune and more boost?
or am I reading that wrong?
a little from column A and little from column B.
I know what I'm talking about and being a smart arse.
if you think that your RB25 makes 300rwkw using standard capacity and a GT35 on 10psi, you're either a YANK or you're confuisng KW with HP.
Maybe you should have your "seat of the pants" dyno re-calibrated.
had car dynoed at rotary motorsports last week
6psi-258hp
18psi-320hp
leaned out at 5500rpm needs fuel system upgraded
:worship::P
Wow...
so it made 258HP (192.5kw) on 6psi
and 320HP (238.8kw) on 18psi.
But it makes 402HP (300kw) on 10psi like you said before?
Must need a tune..
Or does the turbo start turning backwards after 10 psi?
Maybe you can go back and edit your BULLSHIT posts.
then have a moderator delete this post for bagging out your bullshit lies.
is that all, u got that from a gt35r my mate nearly gets that from his hiflow but still a nice car, so wats missing to make this a 300rwkw monsta
thanks mate
well i found out that it still running standard fuel system, no cam gears, no aftermarket ecu, also running rb20 airflow meter, no aftermarket coil packs and its runnin a stock auto.
car has never been dyno tuned so this car has so much potential.
ben at rotary motorsports said with all this done and a few hours on the dyno it will pull 300kw easy.
Edited by DRR33
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
