ive been using kitten and armorall... if you do it every weekend it keeps it looking secksay!
But I hear armorall can be bad for the dash, the dash will start to crack immediately after you stop using it.
Edited by Go Go
https://www.sau.com.au/forums/topic/190335-protecting-dash/#findComment-3428448
Armorall is a dirty word in the car detailing business for a good reason. I'd never put it anywhere near my cars.
Over at the DA forums they recommend Final Inspection General Purpose Cleaner (GPC) to clean the dash leaving minimal residue and then Lexol Vinylx to bring it up nice without being oily.
GPC is $18 for 500ml spray bottle and can be used anywhere inside the car to clean anything
Lexol Vinylx is about $22.
To order these products you can call the Final Inspection Boutique at (03) 9387 8008. I'm in no way affiliated with these guys btw, i've seen some of what these products can do though.
You can likely get Lexol Vinylx at a lot of other places too and use any good general purpose low residue non corrosive/non abbrasive cleaner inside to get the same results. If you want to spend a little less just use clean warm water before applying Vinylx.
https://www.sau.com.au/forums/topic/190335-protecting-dash/#findComment-3430672
