Make:Skyline
Model:R33 S1.5
Milage:126XXXkms
Colour:BLACK
RWC supplied?YES
Currently registered? Yes registered until April
Price:$14000ONO $13250ONO
Contact:Stan 0431 400 297
Comments / Modifications:
First owner in Australia, have had car since April 2005 and it hasn't missed a beat. Car runs great...pulled 165kw on the dyno a year ago...haven't put it on the dyno recently
Has a 3inch exhaust, air filter, 17 inch wheels, alarm, custom dash with dvd player and 7" screen, Greddy turbo timer, RAZO gear knob, personalised plates R332NV
Car is serviced every 5000kms, runs great and is a clean example.
This is my mates car so you can either call him - Stan or leave a message here..car is for sale as he is going overseas to Thailand so needs the money. Price is negotiable.
Images:
Edited by [SKYXTC]
https://www.sau.com.au/forums/topic/190343-black-r33-gtst-s15-1995/
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
