Hey People!
Can anyone give me a rundown/walk through on all HICAS equipment removal? Pref. in a 32?
Whats all the HICAS equipment weigh?
Is it worth it?
Was there much of an improvement?
Cheers,
Cris
Edited by GTS4WD
https://www.sau.com.au/forums/topic/190345-r32-hicas-removal/
theres already a bunch of threads,,,,search if you want to get technical but
i think with oil all up it weighs about 27kgs(from what ive read on here)
it looked close to that when i seen it ALL out of my car.
i prefer it now compared to when hicas was in there.
but many people have different oppinions.
cost me $80 for the lockbar and about 1-2hrs labour from local suspension shop.
Cheers mate..
Ill look that up more indeapth.. im looking for a technical explination.
What do you mean other prefer it in the car?
Oh.. and btw. Just Jap in Syd have a set of R32 GTR wheels with tyres.. have a look on their site..
And from memory there is a set floating around on e-bay. dont know its ended or not yet.. worth a look..
Cheers mate
:D
with HICAS in place it makes it really hard to control or rather predict the car's steering response, and with it removed its basically RWD oversteer. i found in the GTS4 it definitely helps during spirited driving, as half the fun of ATTESA is keeping the foot planted and steering straight when things get a little wobbly.
Hmm.. can you go a little more technical?
I find with mountain roads that the attessa isnt used much.. its it possible to induce ATTESSA to kick in? Corner angle? Speed?..
hmm.. how much does it induce oversteer with HICAS removed?.. I dont want to be down a windey rd and cop a handfull of oversteer. Thats my biggest fear. If HICAS will help stop that. I may keep the system.
How do I get ATTESSA to work with me during spirited driving?
well on the trackdays I've been at I've noticed that ATTESA only sends power to he front wheels when the steering is relatively straight, ie not when the wheels are turned, so its not like you get AWD around a corner. But what I dd find with HICAS on say motorkhana days where you do a lot of turns was that the back would start swinging out around a corner, which is normal for a RWD car, but then HICAS kicks in twitches the back wheels, and makes it really hard to control. Took the HICAS out and I could countersteer and feed the throttle and control the oversteer... which meant that I could get the steering straight quicker, and therefore get on AWD between turns... instead of simply fighting the steering.
HICAS is great for day to day driving, highway driving etc, but on the track, and in the wet can make things bery hard to predict.
So say for alot of togue and mountain roads its better to take it out?
Its just that I have a fear, on any road of oversteer, I think I need a drift day to overcome this fear at high speeds.
I feel aslo, that my ATTESSA is at a bit of a waste as the car now has an RB25DE in a heavy four door, so its quite hard to get enough power to get ATTESSA to kick in..
Any more comments are greatly appreciated!
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
