This as new (turbo's are less than 1000k old) full kit includes turbo's, wastegates (1.2bar spring), manifolds, dump pipes, TRUST front pipes (heat wrapped), intercooler piping (hot side only) and all braided water and oil lines (over $600 worth). Turbine housings, dump pipes and manifolds have all been ported and matched for increased air flow as well as been ceramic coated in "hi temp" black. Compressor housings and intercooler piping has been coated in "cerami-chrome". All ceramic coating cost over $1000. Makes over 500AWKW on 25psi and good for 9 sec quarters.
$5500
https://www.sau.com.au/forums/topic/190363-full-hks-gt-rs-turbo-kit/
  • 3 weeks later...
$5500
over 220 views and not even a nibble...dont buy a half done turbo kit for $3500 ( like this http://www.skylinesaustralia.com/forums/Fu...cm-t192192.html ) and only get turbo's and some intercooler piping...this is the real deal...not just a bolt on off the shelf kit but re-engineered to achieve maximum results. All HKS branded gear from the air filters to the cat flange (except TRUST B-pipe). Try buying all the parts modifying, coating everything then redoing all the lines in top shelf EARLS fittings (not cheap chinese sh1t). This set-up is producing over 5500rpm of peak torque and producing more AWKW than most big laggy single set-up's.
Buy your GTR a Xmas gift today!!
  • 6 months later...
whats on going on the car now?? i can see a low 9 sec pass coming
stepping it up...the car will go 9.7's with current set-up but whats the point only going a little bit faster.
when you can go a lot faster :D
Do you have pics of everything thats for sale?
right...ok...pics
turbo's and piping...all ceramic coated in 'ceramichrome' the turbine housings in 'hi temp black'
manifolds and dumps in 'hi temp black' (note manifolds for sale are brand new balance pipe items as shown in earlier post)
turbine housings and cores fitted with EARLS fittings
kit fitted up to engine
oil and water feeds
kit also includes HKS air filters and TRUST B-pipe
Edited by DiRTgarage
