hey guys,
i've got a mate who's got a 91 model s13 ca18de, auto. its all stock, clean paint, green in colour, 6mths rego plus 2 amps and sub and deck, and also stock rims (currently has black 6 spokes, not sure of kind etc) and rear wing (wing not currently on car). Its just had the water pump replaced and the valves are getting replaced (he was told by his mechanic they were bent). Only other problem is the odometer doesn't seem to work apparently (says 108,000 but he thinks there's about 120,000 on it)
He's after 6 for it. Do you reckon that is reasonable? sorry i dnt have any pics at the moment but i am tryin to get some.
Edited by NG0387
https://www.sau.com.au/forums/topic/190369-s13-ca18de/
Hard to say...
I sold my 1990 ca18de 18" rims, stereo, sub, exhaust etc etc for 2.5k earlier this yr. Altho mine was in need of a respray ;)
yeah the paint is pretty clean on it so i dunno how much of a difference that'll make
https://www.sau.com.au/forums/topic/190369-s13-ca18de/#findComment-3428243
I sold my CA18DE with kit, wheels, stereo, exhaust, nismo suspension, immaculate inside and out for 7k around 6 mths ago...but mine was manual. An auto will obviously fetch less and being close to stock I'd say 5k if you're lucky.
https://www.sau.com.au/forums/topic/190369-s13-ca18de/#findComment-3428317
that green is also not the most loved colour.
if he wants it sold, he'd be looking at the type of person looking for a cheap body to do an engine conversion in to.
$3K - $4K would be reasonable.
SR20det and manual box fitted would be about $5K minimum.
you can get an average condition sr20det manual S13 for about $10K - $12K
RB conversion ones are even cheaper.
https://www.sau.com.au/forums/topic/190369-s13-ca18de/#findComment-3428650
how much would an RB conversion be do you reckon? would it be cheaper to maybe do an RB20DE or RB25DE?
https://www.sau.com.au/forums/topic/190369-s13-ca18de/#findComment-3428867
rb20de and rb25de are great engines when used as door stops.
RB20det conversion for someone who takes an auto ca18 silvia to a workshop to drive out with an RB20det and manual would need to bring about $5K with them I'd say.
check NS.com for others that have done a conversion.
it would be a lot cheapr if you had the equipment to do it yourself.
half the cost is labour really.
https://www.sau.com.au/forums/topic/190369-s13-ca18de/#findComment-3428990
Having said that, I almost bought a black S13 with RB20 conversion for $10K.
it also had, exhaust, fmic, gtr injectors, rb25 turbo, remaped ecu, aftermarket radiator and large thermo fan, 5 stud conversion, R32 GTR wheels, R32 GTST brakes front and rear, R33 GTR seats, Tein coilovers, 17x9 mags which looked decent with lots of rubber, aftermarket clutch and flywheel etc etc..
basically, it was a registered, legit rb20 converted S13 with great list of mods for an asking price of $4K more than what your mate is thinking for his car.
get me?
https://www.sau.com.au/forums/topic/190369-s13-ca18de/#findComment-3429000
get me?
i get ya mate.
Thanks heaps!
https://www.sau.com.au/forums/topic/190369-s13-ca18de/#findComment-3429021
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
    • That's odd, it works fine here. Try loading it on a different device or browser? It's Jack Phillips JDM, a Skyline wrecker in Victoria. Not the cheapest, but I have found them helpful to find obscure parts in AU. https://jpjdm.com/shop/index.php
    • Yeah. I second all of the above. The only way to see that sort of voltage is if something is generating it as a side effect of being f**ked up. The other thing you could do would be to put a load onto that 30V terminal, something like a brakelamp globe. See if it pulls the voltage away comepletely or if some or all of it stays there while loaded. Will give you something of an idea about how much danger it could cause.
    • I would say, you've got one hell of an underlying issue there. You're saying, coils were fully unplugged, and the fuse to that circuit was unplugged, and you measured 30v? Either something is giving you some WILD EMI, and that's an induced voltage, OR something is managing to backfeed, AND that something has problems. It could be something like the ECU if it takes power from there, and also gets power from another source IF there's an internal issue in the ECU. The way to check would be pull that fuse, unplug the coils, and then probe the ECU pins. However it could be something else doing it. Additionally, if it is something wired in, and that something is pulsing, IE a PWM circuit and it's an inductive load and doesnt have proper flyback protection, that would also do it. A possibility would be if you have something like a PWM fuel pump, it might be giving flyback voltages (dangerous to stuff!). I'd put the circuit back into its "broken" state, confirm the weird voltage is back, and then one by one unplug devices until that voltage disappears. That's a quick way to find an associated device. Otherwise I'd need to look at the wiring diagrams, and then understand any electrical mods done.   But you really should not be seeing the above issue, and really, it's indicating something is failing, and possibly why the fuse blew to begin with.
