Hi everyone, this is my first post and I am looking for some gearbox advice. The box in my 3-2 is on its last legs and I am considering a conversion rather than a rebuild. The obvious choice seems to be the R33 box, but the cost of this conversion seems a little prohibitive and the speedo / trans-tunnel / driveshaft/ cross-member modifications strike me as being a lot of trouble.
I have my eye on a S13 SR20Det box and from what I have heard it will bolt straight up once the bell-housing is swapped and a custom tail-shaft is fabricated. Is this correct? Also, the speed sender is apparently compatible, so no modifications on that front either. My main question is if anyone has had experience with this sort of conversion or perhaps a similar conversion using an S14 gearbox? Would a R33 RB25De box be a better choice?
Any help would be much appreciated.
Cheers.
https://www.sau.com.au/forums/topic/190402-sr-gearbox-in-an-r32/
shifter position is different also.... not worth the expense. considering rb20 boxes go for 150-200 bucks.
i have about 10 sr and rb20 boxes at home i use for spares and they are weak as shit.
r33 or 34 or if you reaaly want 300zx are the only worthwhile conversion.
I've heard that RB20 boxes are similar to CA18s in terms of strength and that SR20s are stronger to some extent. My main reason for leaning towards an SR20 gearbox is how cheap an OS Giken triple gear-set would be several months down the track :(. But I guess I'll either have to swap in another R32 or go all out with a R33 gearbox. Thanks for the advice.
Edited by touge32
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
