  • Replies 54
Posted Images
:turned: yay no damage under the car :w00t:
as for the hicas its going in the bin and a lock bar is going in it's place thanks sambo33 sounds like a plane
no worries, i got mine from greenline, but it looks like theres some for sale on the forums too
http://www.skylinesaustralia.com/forums/t183517.html
thanks hun im about to put it on a hoist just to make sure that nothing else is damaged and ill get my mate to look at that, i was going around a bend to the left and it just went out from under me so i went to power out of it but that was the bad move i think cause that is what threw me towards the gutter what do you think i should have done?
Look, I wasn't there, but it sounds to me like you simply went round the corner too quick and lost it.
HICAS only moves +/-0.5 degrees, and as said just leaves you a bit of a "vague" feeling on the edge.
It's not VTEC yo! and doesn't go about randomly and violently kicking in under normal operation.
Sorry to hear about ur car Kellie... cable ties & gaffa tape ftw !!
my hicas is a bit knackered, just like with Cubes under hard acceleration it can apply itself, making me have to counter steer slightly to the left... and it returns under deceleration, pretty sure the rack or the rear pump is fkd. Just gotta find time to rip out all the unwanted pump and lines when i chuck in my lock bar and lose that extra 30kg :P the guides say it takes a few hours.... so im gonna allow days :rolleyes:
So let me see if i got this right, You own a R33 Turbo RB25 RWD car, You were traveling around a corner, and ur car went sideways, and gave it more stick, and u lost it into a gutter, and ur blaming hicas...
Edited by silverbulletR33
I was in a 32 awhile ago, we were driving in a straight line, I was in the back and I felt a sudden side shift, at the same time i asked Wtfwt the driver said the hicas light has come on, it has happened a few very random times before.
I ditched mine as well :)
i had a 33 gtst and another mates one too, that over 80k's the hicas went crazy. Id be correcting myslf on a straight road.
Turned out to be the little plastic disc behind the steering wheel was crooked.
So hicas does stuff up, you cant assume that a girl (kellie) does not know how to drive, and just put it down to that.
I say good on her, being out there cruising learning her car, its the only way to learn is to know your limits.
Some ppl are bagging her and i bet she could drive better than some ppl on here, at least she is out there doing it.
Thats my 2 cents
mike
I've never had an issue with my HICAS so I don't really know what it's like when it goes wild but to say that the rear wheels turning half a degree has caused you to crash is ridiculous.
No offense (well... not much anyway)
Race__24....toolmaker? fitter and turner?
hey i love that design...if it was cnc do you still have the program??? hehe.
Yeah mate, toolie by trade but working in aerospace now. I don't have the program but can write you one if you want.
i got mine off of Sherwin (NV_NO1), hes quick and is a good seller.
ive got a 180, so mine is a bit different, but im sure the symptoms of malfunctioning hicas would be similar.
before i locked my hicas it actually seemed to have a mind of its own. at low speed, as others have said, it was alright, i could still notice it, but could handle it. it wasnt until i started going 100km/h+ that it really got bad.
it was actually dangerous. the back end just felt like it had a mind of its own. slight corners would make it go nuts and all over the place, and have fun trying to turn abit sharper under speed. there was no way of knowing what it would do.
r33s have it easy when it comes to locking it, as others have mentioned it is electrical.
on s13s it is mechanical. took me a couple of hours to get the tie rod ends out, lock bar in, remove all the lines to the front, remove the actual hicas pump, and then finally run a loop from the outlet that goes to the hicas cradle to the inlet that brings it back.
then there was the hunt to find the right wire to cut to get the light to go out on the dash.
worth it though, the before and after difference is really very good. but thats coming from hicas that had a mind of its own. if it was working correctly im sure it would have served its purpose properly.
not sure bout 33's but i gots 32 that had hicas but got taken out n an S13 rear cradle got put in.
bolts straight up n is shyt load lighter,
i would recomend that to ppl if they want hicas gone in there 32 for good
Possibly a weakness with the hicas elec setup.
Mines only recently started playing up but granted I have had the car for ~6years and travelled ~181,000km's (total odo 248,000) so she's done well.
The cars still a million times better than the old VS 5ltr 5speed I bought that was near new back in 1999 with low km's. From day one the interior rattled, had alternator, inlet manifold leaks, gearbox, diff and rear IRS subframe problems. The little ol' R32 has zero rattles, still drives well, still on the same alt, power steer pump etc.
thanks to those that slaged me yeah i was going fast but you all were not on the cruise and i didnt ask for you all to be nasty so thanks :P
love all of you that were helpful and gave me some tips on how to fix/evaluate the problem :P
thanks michael for sticking up for me :D
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
    • Yes. All of this. But even when you get the NOx as low as you can go on an RB, it will no doubt still be way too high. Same with CO and HCs. The tech and the tuning time just isn't there.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
