Bought the car with a complete Trust single turbo conversion already done (it had a T78 turbo at the time).
Kit:
Trust manifold
Trust wastegate
Trust twin air filter set up
Custom stainless steel exhaust housing cover
Garrett t04z (0.84 rear, 0.70 front)
Braided oil line
Custom BOV return pipe to intake pipe
Turbo 10k old.
387rwkw on Racepace dyno on 21psi
Will not seperate.
Keen on doing a swap with someone who has twins, preferably from Melbourne.
Price: $2700
edit: now with dyno sheet
https://www.sau.com.au/forums/topic/190458-rb26-to4z-single-turbo-conversion/
man thats so cheap it aint even funny...
Any particular reason for sale? apart from the fact that you will get bent over hard here in vic if they pop teh bonnet??
benm
pm sent
Yes i do, i need to scan it.
femno
I am after more response for circuit work.
My other option is a go for a smaller single as well.
I don't drive the car much so that's not an issue for me.
Friends of mine in Melbourne have twins: Jacob and Max. They'd happily swap them for the turbo kit :P
Swap for Vspec twins with steel wheels?
I will be coming down to Melbourne this weekend if your keen. Is the set up off the car? if so can you provide pics of the intel and exhaust wheels.
Cheers
let me know if your still up for a swap, i have a few twin setups including the pipework you see below.. We are going single next year (K5-660R) so i can use all your gear bar the turbo.. i am happy to take lot then sell off the t04z. so if some-one wants the turbo separate....
Trent 0407 059280
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
