Make: Nissan Pulsar GTi-R
Model: RNN14
Milage: 196XXX
Colour: Metallic New Ford Blue
RWC supplied? Maybe
Currently registered? At the moment, yes
Price: 15k
Contact: Myself
Comments / Modifications: Some :turned:
Images: Yes
Hey everyone, so I'm selling my GTi-R Pulsar, as Im in the need for a bigger car.
Its an amazing car to drive, they really are what they're called "pocket rockets".
It sticks to the road like its on train tracks. Iv'e even had people that own GTRs say "holy crap".
The car is an absolute HEAD TURNER!!! weather it be the sound of it coming, or the look of it, everyone stares!
Since Ive owned it (2nd owner in AUS) I've only ever had 3 problems with it, the stock fuel pump started to struggle so I replaced it, as you can see in the mods list. And it had a bit of an exhaust leak between the block and the turbo, which a promptly got fixed, and it had a bit of a gearbox issue, which is also fixed (replaced the whole gearbox).
Anyway...
Here some information on the little beast -
The good
Its got a front mounted intercooler, Apex'i Power-FC Computer managment system, Apex'i avc-r boost controller, Bosche 440 fuel pump ( rated at 500 hp), custom intake plumbing, a full 3in exhaust system, carbon composite clutch with high pressure nismo pressure plate. After market shockies with all neoprene bushes. The Battery has been re-located to hatch, Its got a boost gauge, and a noisy BOV.
Also has a killer sound system in it, which I may consider leaving in for the next owner, If i get a reasonable price.
Being : An alpine mp3 head deck, Wicked front speakers with tweets (I can't remember what they are, but they were the best sounding ones in there at the time, Alpine "R" rear 6x9s, and 2 Blurpunkt subbies (they pump!)
The Bad
A few little spots of paint missing (one due to it bottoming out on a pothole OUCH!) Which is easily fixable.
Im asking $15000neg.
Contact me on 0439723150(matt), or alternitavly on 0406638919 (steph)
https://www.sau.com.au/forums/topic/190469-off-tap-mini-gtr-qld/
OK everyone,
The new gearbox is in, and it feels nice as pie!
Also, price drop 14k NEGOTIABLE
I need this thing gone, if you have a realistic offer, please do it, i need this gone asap
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
