There was a problem at one of the refineries and they haven't been delivering for over a week now, apparently a problem with the fuel itself. Truckies were being told to fill up before going to Melb because there was little/no fuel.
No one else heard about this? You'd think it would be bigger news.
https://www.sau.com.au/forums/topic/190483-fuel-in-melb/#findComment-3430388
My BP station (ferntree gully/burwood hwy) was out of Premium 95 and Ultimate 98 for over a week. They managed to get some Ultimate this week but are still out of Premium 95.
Just filled up a full tank of ultimate98, car's acting sorta funny now lol
https://www.sau.com.au/forums/topic/190483-fuel-in-melb/#findComment-3430402
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
