  • Replies 91
Posted Images
here's my ceff, Uras NS-01
17 x 9.5 +15 front, s14 LCA's, 20mm flared front
17 x 9.5 +15 rear with 25mm spacer= -10, custom flared metal guards
needs more low tho :)
technically yes, but if you imagined the spacer was apart of the wheel, the wheel would be neg 10.
Rear gaurds are pimp NICKCEFFY, haha you can see half the rear tyre pretty much.
demsA31 also looks the goods, makes me want a kit..
Cheers mate,
yeh love the big proper formed guards!!
makes me wanna do the laurel now as well, but then i've gotta get new rims for that as well!!! :cheers:
Edited by NICKCEFFY
Flushhhhhhhhh
Pants tighten everytime you look in the side mirror and just see the edge of the wheel chillin outside the guard.
Flushhh FAIL in the front by about 1.5cm. Didn't realise that the guard would flex so much when rolled. will need to get longer bolts and space it out or buy more Godfathers... MOAR GODFATHERS!!!1!
Fronts are 18x8.5 +35 (with a 3mm spacer to clear the strut) and rears are 18x9.5 +35 (perfect IMHO for cef)
Tyres are 215/40/18 in front and 225/40/18 in the rear, which tucks in under the rolled guard nicely, and still retains the crease line on the guard.
If I was to get another paid for the front I'd go 18x9" with a +25 or +26 offset. That would clear the strut AND space the outside of the wheel to be FLUSHHHHH with guard.
I might try R33 LCA's to try and push the track out a lil, but with the car running shocks and springs instead of coilovers, I can't have camber tops to cancel out the negative camber longer LCA's will give me :cool: Or is my theory flawed?
Hey man, wheels look good..could have gone a few mm lower, but Im a fan of low offset :devil:
Funky, yours look good too. Maybe a slightly skinnier rims with lower offset would be good, avoid having to use spacers?
I wanted to go +25, But I couldn't find any that I liked.
(You were responding to me, right?)
Edited by DanShirts
yeah I'm gonna keep looking out for anothe rpair of godfathers in 9" with a +25 offset for the front, till i find them I'm just gonna lengthen the hub bolts and run 20mm spacers on the ones I have now to bring em out.
Cant really tell you about these rims.. Off a mates HR31, 16" 225/40 I think.. Knew the offset would be horrible, but we did it anyway! :banana:
Never bothered to put the suspension back in the front after Regency, as I drive it everyday. Not worth the hassle..So sit on the bonnet it was!
Was all for shits and giggles. :banana:
  • 1 month later...
  • 1 month later...
  • 4 months later...
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
