Was looking through my garage just then, found these 3 turbos T88 and two turbos with "A/R 42 M24" writing on it (T28? GTR Turbos?)??
The question is how much can I sell those turbo for?!!? they are in good condition, no shaft play whatsoever, but it's just a bit dirty cuz it's been sitting there for like 2 years now...
Or do u guys think I should do a single turbo conversion in my upcoming R33 GTR? :whistling:
https://www.sau.com.au/forums/topic/190505-greddy-t88-34d-and-t28-x-2-turbos/
In my opinion TWINS FTW!!
Over a big single they offer better response. They do cost a tad more but factor in a new exh manifold, inlet modifications etc and there goes that saving from a big single.
Stick with twins; better response on that rolling acceleration out of a corner etc.
2 x GT2530's, dumps, cams, cam gears (spool), injectors, pfc, nice exhaust and you really can't go wrong. :whistling:
If your handy with a spanner pull the head off while its apart and drop a 1.5mm restrictor up front and replace the std h/g with a MLS type trust etc.
The restrictor prevents too much oil floating in the head during extended high rpm's (i.e mallala). If its apart you may as well; its not all that much more work to remove the cam belt a few head bolts and pull the head off. If not just ensure you keep the sump overfilled. :P
more info please :(
The car is in NSW, fully built and forged engine, should hit about 1100hp without nos, and minimal lag due to the supercharger...
There is a LOT of info, that isn't even the technical side of it :P
I have some of it on the block with the supercharger, but they are at home...
If you want more info, ask here, or better to probably shoot me a PM...
Oh yeah, and it's not finished yet, but i believe it is close to completion...
Hmm, thinking of selling my Greddy T88-34D turbo as I won't be putting that turbo in my car hehe, how much can I sell them for? it's new I think, I will take some photos and post it up tomorrow.... and with my other two turbos hmm, it says Garrett A/R 42 M24 1-2, and what's that "1-2" meant? anyone?
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
