Gt5 Prologue Best Circuit Times
Triptych
 Share
make a japanese account if you need more help PM me and I will send you all the info you need. Once you have downloaded the demo it will available on all your accounts on your PS3. Remember the demo is only available till early november if i remember correctly.
Ok you guys had me working hard on this. My worse corners are the Hairpin and shacane (mind the spelling its late). I have got those corners a little better now and I had times around low to mid 4'30 put didn't want to post till I was number one again :) . I mastered the first corner in 4th and second corner in 3rd which shaved off the extra time I needed plus getting my worse corners better. This is still with the sixaxis as the table for my G25 is currently getting built.
Ready to rise to the challange?
Car:GTR 07
Front Tyres: R3
Rear Tyres: R3
Complete Time: 4'29.595
nice! well I'm officialy rubbish. I get 3/4s through an awesome lap only to throw it away somewhere. :)
my best laps are stil a 18 first lap and a 12 second lap but I can never get the two together. I've gone backwards in fact I tend to be in the 34-36 zone now with an off or two somewhere. ;)
Josh your lap doesn't count because I knew you would do that, Having a better lap time ready for when I finally beat yours. I spent about 4 days trying to break 4'30 mark and that lap that I did it on was luck I think. Now you expect me to even better it again.
I should disqualify you for have a 180sx in your name and nothing to do with skylines :)
Back to track over the weekend for me, I pick up my puppy tomorrow so hopefully he wont try to steer the car for me.
lol at least now you have incentive to keep playing and get better! I have the type x because when i made my account i had a 180, but since then i've had an R33 and R32 (in the space of just over a year lol).
I still suck. had about 10 attempts and can't put it all together. I was on an awesome lap just up to the turn before the back straight, had already passed all car (usually I get the last 1 or 2 on the back straight) and my gf walked in front of the tv, and I ran wide. dammit.
so I gave up and played warhawk instead. and yes I'm pretty ordinary at that too. haha.
  • 1 month later...
did a 4:27. not sure if that's good, but it was my best, and I had an off at the hairpin. did a 2:17 first lap (good lap) and a 2:10 second lap (could have been a bit better).
and I only just picked it up again today and it was my second go. :banana:
 Share
    • As someone who has been playing with turbo things for some time now, be prepared for this to not be the first time feeling this way    I'm busy as atm, but if no one else covers the things I'm realising are worth mentioning to you then I will when I have a chance as it seems like I overestimated your knowledge on how turbos and wastegates work.  Otherwise I recommend having a look around how wastegates and boost control work, really anything on understanding the general mechanism of boost control as it will help you find the answers to the questions you're looking for.  Your initial question jumps some fundamentals.
    • I don't understand anything anymore.
    • so this is an anomaly??? I thought it was a voluntary increase
    • we can only guess exactly what happened from our keyboards, but to me it looks like they were targeting 27 but the wastegate was too small or poorly controlled and the boost crept up, that is quite common
    • Good points!  Took those for granted - though I *did* actually give an example of winding boost up more than it had been before where I wasn't actually specifically looking for more peak power.  The Toyota Starlet dyno plot that I shared and mentioned showed an overlay from the previous tune it had and the one I'd redone, I left the boost targetting the same as the old tune but then after peak power I ramped boost up by a good 5psi or so over what the old tune had at the same rpm. The reason I felt comfortable with this (though the owner of the car had a "are you sure?" moment when I suggested it) is that the setup wasn't turbo limited, it was largely head sealing limited and the owner was a bit concerned as for the last few seasons he'd had issues with head lifting - sometimes not completing an event without having some headgasket issue, so he didn't want to run any more boost than it was. The reasons I was ok with raising the boost a good 5+psi MORE than that was that I left it where it was in the middle, and only increased it where VE (and therefore cylinder pressure vs psi) were dropping hard and I didn't stop the torque from dropping, just reduced the drop.  Well, there is that and the fact that the previous tuner had it overtimed by near 7degrees at peak torque - but that's another story haha.    I didn't really go into detail about that "turning it up more" thing but now you've mentioned the "not detuning", sometimes the boost *can* be turned up higher than you'd expect if the setup allows for it and you do it smartly.  I've tuned things to run 30psi on BP98 "safely" that a few years ago (or still?) people would cry that it was a stupid idea - but given they were well intercooled, low EMAP turbos and only doing that kind of boost where VE is dropping etc I was pretty confident it wasn't as cowboy as it sounded at face value and we never ended up with issues as a result of it.
