I have a r34 with the pop up display on the dash. The car has there control panel for the display where the climate control is and the climate control is the next one down, the problem i have is that the cd player that is in the top part is not working properly and this is making me made. Is there any options for this pop up screen that can be interfaced with it or any other ideas even some form of engine telematry.
Cheers Andrew
https://www.sau.com.au/forums/topic/190569-r34-pop-up-diplay/
mm is the screen jap? like did it came with the car..
coz i have a in-dash unit too (blue) came with the car from japan, and it also didnt read any cds, and had very low radio frequencies,
i just took it to a car audio place down the rd and get it fix, hope this helps :thumbsup:
Yes the screen is in jap. It is in the top of the dash where the triple gauge cluster goes and it has sat nav and t.v. and the cd goes in to the control unit that runs the screen. Might have to take it to a stero place and see what they say, the cd works some times but not always.
pop out th ashtray and lower panels - remove screws, pop out AC ducts up top remove screws whole assy comes out. you will need two antenna adapters and hte band expander. I keep those here if you want them.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
