  • Replies 76
Two different quotes and two different interpretations.
Now if you believe that using cut slicks would enable the GTR into the 7:30 then your dreaming.
We shall see when the first production GTR actually tries to tackle the ring, whether or not its as fast as the CGT.
It says around 7:30 in the dry with cut slicks and that 7:38 was on a partially wet track.
Who knows until it happens.
what makes you guys think that nissan is the only company that do their best within what they think is 'fair' to get a good time? what tyres did the porsche use... etc etc.. why is nissan the only time people seem keen to challenge. I would trust them over the german marques to set an 'honest' time.
I have spent plenty of time in Germany and Poland, the chances of getting a dry track depend on weather conditions which are good for a substantial part of the year.
A little bit harder around the ring though with its changes in elevation, or so ive heard. Its a bit like Bathurst.
I just watched the video. you can see what tyres they are using. regular street spec bridgestones. why would they use anything else? you can even hear them protesting in the video. I've never heard slicks make noises like that. not even semi-slicks sounds like that.
I've already seen this discussion on another forum...
You can see them put the tyres on in their video. They are Bridgetstone RE070 tyres. The same tyres they supply with the GTR from the dealer. Why would they use anything else?
I've got no idea on what monarocountry is trying to get at here.
He's blabbing about the 'cut-slicks' on the ls1 forums aswell. Me thinks that someone is in denial that the GT-R is indeed an absolute legit weapon.
Pretty pathetic attempt to try take the light away on what truly is a remarkable piece of machinery.
Cheers,
Steve.
The Nissan, the... we all know that no one who speaks German could be an evil man!
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
    • Well, you wouldn't use 2nd hand bearings out of another engine anyway....so just buying the proper bearings is obviously what you're going to do. The crankshaft would be common. The conrods might be common. There is essentially nothing else you would be able to use.
