eddieeeee-ro Posted October 24, 2007 Share Posted October 24, 2007 hey guys got a walbro fuel pump from slide.. only came with pump and the white filter thing... didnt come with the connector... anyone kno where i can get one? Link to comment https://www.sau.com.au/forums/topic/190594-walbro-fuel-pump/ Share on other sites More sharing options...
RBwhatever Posted October 24, 2007 Share Posted October 24, 2007 Connector? You mean the plug that plugs into the top of the pump? Link to comment https://www.sau.com.au/forums/topic/190594-walbro-fuel-pump/#findComment-3432145 Share on other sites More sharing options...
eddieeeee-ro Posted October 24, 2007 Author Share Posted October 24, 2007 yeah, cause the standard o-ring doesnt fit on the walbro... i only got the pump and filter... didnt get the install kit with the hose or wire plug.. Link to comment https://www.sau.com.au/forums/topic/190594-walbro-fuel-pump/#findComment-3432156 Share on other sites More sharing options...
RBwhatever Posted October 24, 2007 Share Posted October 24, 2007 I just used 2 female insulated terminals. They push on nice and tight and do the job just right. You can pick up some terminals at a repco or auto sparkys for a bout $3 or less. Here's my install. http://www.skylinesaustralia.com/forums/t1...87#entry3337787 Link to comment https://www.sau.com.au/forums/topic/190594-walbro-fuel-pump/#findComment-3432157 Share on other sites More sharing options...
RBwhatever Posted October 24, 2007 Share Posted October 24, 2007 (edited) You'll need a crimper. I also just cut the bottom of the bracket off so the pump fits easier. I stripped the wire back and soldered the wire before I crimped onto them too. You need some more hose to reach the pump as well. I used the extra hose and cut it up and used it as mounts to prevent excess noise. And just tightened up on them and the pump with 25mm-50mm hose clamps. Edited October 24, 2007 by KeyMaker Link to comment https://www.sau.com.au/forums/topic/190594-walbro-fuel-pump/#findComment-3432184 Share on other sites More sharing options...
Simon-S14 Posted October 24, 2007 Share Posted October 24, 2007 out of curiosity, whats the walbro good for at 13.8 volts in terms of rwkw? Link to comment https://www.sau.com.au/forums/topic/190594-walbro-fuel-pump/#findComment-3432488 Share on other sites More sharing options...
eddieeeee-ro Posted October 24, 2007 Author Share Posted October 24, 2007 250rwkw's? Link to comment https://www.sau.com.au/forums/topic/190594-walbro-fuel-pump/#findComment-3432753 Share on other sites More sharing options...
sl33py Posted October 25, 2007 Share Posted October 25, 2007 My mechanic has been fitting Walbros for years and has some R33s using them and 300rwkw. Link to comment https://www.sau.com.au/forums/topic/190594-walbro-fuel-pump/#findComment-3433102 Share on other sites More sharing options...
STATUS Posted October 25, 2007 Share Posted October 25, 2007 out of curiosity, whats the walbro good for at 13.8 volts in terms of rwkw? cats car had no issues making over 300rwkw with it. The car now runs a tomei pump but the only reason i swapped the walbro out was because it was nearly 2 years old... i have no doubt it would have continued on no dramas Link to comment https://www.sau.com.au/forums/topic/190594-walbro-fuel-pump/#findComment-3433170 Share on other sites More sharing options...
abu Posted October 25, 2007 Share Posted October 25, 2007 cats car had no issues making over 300rwkw with it. The car now runs a tomei pump but the only reason i swapped the walbro out was because it was nearly 2 years old... i have no doubt it would have continued on no dramas Is that the exact same one that SLIDE sell's, or a different version? Apparently there is 2 different versions, ones a high flow (HF) pump someone mentioned? Link to comment https://www.sau.com.au/forums/topic/190594-walbro-fuel-pump/#findComment-3433175 Share on other sites More sharing options...
STATUS Posted October 25, 2007 Share Posted October 25, 2007 ^ sorry i only buy from reputable dealers so i know what im getting, especially when we go through like 200 a month. Not a dig at slide more a general comment... Link to comment https://www.sau.com.au/forums/topic/190594-walbro-fuel-pump/#findComment-3433185 Share on other sites More sharing options...
Simon-S14 Posted October 25, 2007 Share Posted October 25, 2007 thanks for that trent! good to know that my pump will do the job with a new turbo then Link to comment https://www.sau.com.au/forums/topic/190594-walbro-fuel-pump/#findComment-3433259 Share on other sites More sharing options...
