ROFL i pulled my dump/front pipe off using only 2 hydraulic jacks and 2 car stands.....and a good hour of f!@#ing around figuring out how to unbolt off the turbo lol ...the two on top and bottom closest to the guard is easy to take off, jsut use a breaker bar :P only real need for the hoist is to unbolt off the cat (piss hard BUT do-able when chassis is an inch off ur face!) hardest one to get to will be the middle one on the side of the turbo facing the block.
it WILL be hard for a first timer, but definitely do-able! i should make a bet too lol trust me you might be sore and bleeding off ur face but you wont regret giving it a shot! really good learning experience (and yes i did hit myself in the face with a spanner......)
I bet you $135 by the end of it you'll wish you paid someone :)
so how bout that $135??? :D
2 hours and with help from a mate didnt use a hoist we ended up using jack stands and ye now its all installed. car sounds so much better and goes a bit nicer to :P
so ye Adz want my account details??? lol
We used a friends hoist as well for the 32, and I can tell you now that after all the freakin pain trying to get the zorst off and new one on, I would be more than happy to pay $135!
Jacking up the 180 about 1m at the back just to change a catback.. also pain in the arse.
You just never know how many 15yr old bolts you're going to snap til it's too late..
I even snapped my brittle radiator drain plug once.. luckily we have 2 other (Nissan) cars here with the same size plug :P
so how bout that $135??? :)
Hahaha, help from a mate? Them's cheating words :P
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
