Must be willing to ship to the United States. Will do my best to make it worth the trouble. Cash and anything from the US you can't get in Australia...if there is anything. :P
May also consider RB25DET, SR20DET, and RB20DET clips/motors if you want to get rid of them.
Originally posted by Clint32
What about a 180sx, stripped and fully prepped with full suspension setup, rolling with no engine
Both of you guys throw up some pics or e-mail them to me at
[email protected]
with a price and a shipping estimate. I've gotten shipping estimates from GCT autos in Japan and they quoted me $2,100 to any port in the US. Seemed a little high...hopefully you guys could do better. :D
would it be worth ur while. what do skylines for for in the US? lets say r33 gts-t full car low k's stock. how much in the US (without compliencing)? This could be turn into a profitable business?? maybe playin the exchange rate at the same time :)
I'm importing for myself and to help my future business.
But, I would think it would be easy to sell them in the US....there is definitely a market depending on how much it will be to obtain them. I'm definitely interested if you think you can supply them for a reasonable cost.
I would think that a rolling chassis over here might bring $8,000-$10,000 US dollars. With engine installed and registered....maybe $20,000 for an R32, $25,000-$30,000 for an R33. US Dollars. Those are educated guesses...no guarantee.
whoa! OMG. now thats profitable. If i was u and had the capital. Fly to Japan with lets say US$50k, bring back about 20 cars or so and BAM! u'll have about half a million in ur pocket if u can sell the cars at the price u just stated. ANywayz before u do that, u want to buy my r33 gts-t?
Probably a little steep for me right now, but I believe my cousin (who is my business parntner) may want to.
Since he is in the US as well, you will have to remove the motor. Of course, he really wants a GT-R. I'll ask him though.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
