Hey all.
Just wondering what kind of power numbers I would expect to get form my 32 GTR with the following done to it.
Apexi Power FC with boost controller.
Sard 800cc injectors.
HKS 272 deg cams
Adjustable cam gears
N1 turbos.
Head been port and polished.
Bosch 044 fuel pump.
I was hoping to get over 350 rwkw. Am I dreaming or not. If I am what else do I need to do to get those sort of numbers.
The car is currently making around 250 @ 14psi.
Edited by GTROB
https://www.sau.com.au/forums/topic/190647-power-out-put-from-r32-gtr/
A GTR with an exhaust, stock turbos, Power FC, cam gears and 14psi will usually make in the region of 250rwkw so considering your car has larger turbos and cams, your current power output is a little down on what it could be.
I think the deciding factors will be:
A) Your Tune
B) The type of N1 turbos you are actually running (R32/R33 or R34?)
C) How much boost you plan to run
Also, are you running a full aftermarket exhaust ie larger front pipes and dump pipes at the moment?
I still dont have any of this stuff installed. So its making that power with all stock parts. Yes it has after market exhaust.
A) Your Tune
350 is going to be a stretch for N1s
Think of ballpark figure closer to 300-320
Not if we are talking about R34 N1's
The last car that I saw running them was a stock engine'd R32 producing a touch over 330awkw on 19psi.
Yeah, totally depends on which N1's.
R32 arent even worth having on the car IMO. Especially the BIG 32 ones, just too laggy.
R33 is a bit better but not great
R34's are the business and will get 330rwkw or there abouts. Basically the same as GT-SS turbos.
    • Also sorry to hear this @DanielStone - I remember @SmoothLine well, he was around for a very long time and was one of the original members of this site.  God Speed Matt. Thoughts with his family and friends.
    • Nice car! Looking at your GTS; makes me wonder why I bought a GTS-t... Everything has been changed anyway. I should have just started with a non turbo model.
    • Rear doors central locking wiring removed and cleaned. See the first 8sec video of when it’s filled with river silt. its a snip of what I’m up against. front and rear doors complete now. Maybe another day removing carpet and bits and pieces. Then the re assembly begins. 🤙 att.DqweJqhY5MZiZYQDVMhn3LtvdD1RBZ7TBG4f2s7W1zM.mp4 att.lFuN22MZEowqCbFAXoDw009r2gHL76ChMVfxMfBX-uk.mp4
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
