Transcript of thios mornings article in John Mellors Auto News (Industry Type Journal)<<<<<<
GTAaaah!
Nissan finally takes the covers off its GT-R supercar
- due here in about a year with an expected bargain price of $150,000
By BYRON MATHIOUDAKIS in TOKYO
FORGET its awesome 310km/h top speed,
ballistic 0-100km/h sprint time of 3.6 seconds
and Porsche 911 Turbo-equalling 353kW of
power … 150,000 is the number in Australian
dollars that may yet excite GT-R fans the most.
This is the price that Nissan Australia is
hoping to stick on the twin-turbocharged V6
all-wheel drive four-seater R35-series GT-R
coupe when it arrives here in the first quarter of
2009 – or even late next year if all goes well.
Over four years in engineering gestation, the
production car known in Australia as “Godzilla”
was finally unveiled today at the Tokyo motor
show, six years after it first appeared as the GT-R
Concept at the same event, and two years since
that initial show car morphed into the GT-R
Proto concept. Japanese buyers will pay around
$A78,000 when sales commence in December.
Consider also that the latest version of a
series started by the Prince Motor Company
as the Skyline GT-R in 1964 – and briefly
imported into Australia in R32 guise in the
early 1990s – delivers 588Nm of torque (32Nm
short of the Porsche) and can lap Germany’s
hallowed Nurburgring Nordschliffe racetrack
in seven minutes and 30 seconds, while pulling
g-forces of ‘2’ (side) and 1.8 (braking).
In fact, Nissan defines a supercar as a
vehicle with a power-to-weight ratio of 4kg/hp
(0.75kW), having a top speed capability on a
public road of over 300km/h and being able to
lap the Nurburgring in eight minutes or less.
Yet despite the massive capabilities on offer,
Nissan has dubbed the R35 GT-R – an all-new
and bespoke vehicle which has the job of being
its technological showcase for future models –
as the “Multi Performance” supercar, declaring
that it is a year-round proposition that can be
driven anytime, anywhere, and by anybody.
To prove the GT-R’s docility and accessibility,
Nissan filmed an 18-year-old woman in Japan
– with an automatic-only licence – driving
the car and obviously enjoying it. She duly
pronounced it as feeling “great”.
Part of that lies in the GT-R’s debut GR6
dual-clutch six-speed gearbox, which features
a three-mode “A” automatic mode as well as a
two-speed “M” manual sequential paddle and
floor levers that – in “R” racing mode – can
shift up or down in real-world conditions in 0.2
seconds.
Nissan’s engineers claim they had
commenced work on the gearbox – in
collaboration with BorgWarner – almost five
years ago, and had the idea for it before the
Volkswagen Group launched the conceptually
similar DSG dual-clutch transmission in 2002.
GR6 works in conjunction with Nissan’s
ATTESA all-wheel drive system that now
features an electro-magnetic clutch instead of
a hydraulic one, a heat exchanger for reduced
heat build-up and lower friction, a 1.5-way
mechanical LSD limited slip differential, and
dry-sump lubrication.
Torque is usually apportioned 100 per cent
to the rear wheels, but up to 50 per cent can be
diverted to the front wheels.
The engine is Nissan’s all-new VR38
60-degree angle V6 of 3799cc capacity, a
compression ratio of 9.0:1 and a bore/stroke
of 95.5mm x 88.4mm. Its 353kW peaks
at 6400rpm, with the rev limiter cutting in
at 7000rpm. The 588Nm plateaus between
3200rpm and 5200rpm. And the official Japanese
combined cycle fuel-consumption average is
12.2L/100km. This powerplant also rates a US
ULEV Ultra Low-Emission Vehicle status.
Its integrated twin-turbocharged induction
system features electronic boost pressure
control and a secondary air-injection system
for cleaner emissions and improved fuel
economy.
One senior GT-R engineer revealed that
discarding the decades-old tradition of inline
six-cylinder engines for the more common V6
design was not a point of debate, especially
when it became clear that the latter would be
far better suited to achieving the performance,
packaging and weight distribution targets that
Nissan had set out to achieve.
Suspension is by an independent double
wishbone set-up at the front, and a multi-link
arrangement at the rear. It includes Bilstein
electronically adjustable dampers for improved
ride characteristics.
Brakes are by Brembo, and have big
drilled fl oating rotors, aluminium monoblock
callipers (six-piston at the front, four-piston at
the rear) and a large-diameter master cylinder,
for repeated non-fade stopping performance
capabilities. Tests show a GT-R braking from
200km/h to 90km/h can create a 1.5g-force.
Runfl at tyres are used, and are 225/40ZRF20
97Y at the front and 285/35ZRF20 100Y spec
at the back, ensconcing lightweight 20-inch
alloy wheels.
Stylistically, the GT-R will only come as
a two-door coupe. Designer Masato Taguchi
pointed to the front mudguard’s “aero grade
fender” blister and feature line – which also
contains a vent housing designed to help with
airfl ow and brake cooling – as his favourite
styling detail on the car.
Other high points for the designer include
the rear-quarter view, which imparts the GTR’s
strength and angularity of line, as well as
the horizontal crease in the C-pillar, there to
help the fl ow of converging airfl ow at speed
for aerodynamic optimisation. The overall
silhouette is meant to recall previous Skyline
models dating back from the 1960s, while the
“Single Power Intake” grille – incorporated
purely for air-fl ow function – also connects the
latest GT-R with its R34 predecessor.
Three main materials are used in the body
– steel, aluminium (mainly for the bootlid,
bonnet, front suspension strut and seatbelt
housings, door panels and some underbody
bracing brackets), and carbon fi bre, which is
found in the front underbody sheeting area.
There are also various plastic compounds.
More raw numbers: the GT-R’s kerb weight
is 1740kg, while front/rear weight distribution
varies according to equipment levels, but it is
mostly about 53/47.
Developed over three years in Japan and
Britain, underbody shielding under the
GT-R’s nose and tail helps deliver far
more racecar-style downforce while
improving aerodynamic effi ciency – rated
at 0.27Cd.
The interior has been specifi cally
designed to be driver-orientated, evident
in the high-up eye-line placement for all
instrument and monitor displays.
The latter is a multi-function meter
that has a vast array of vehicular motionrelated
tech data inspired – and created – by
Sony’s Polyphony group that is behind the
Gran Turismo PlayStation phenomenon.
With today’s GT-R, life is imitating art that is
imitating life, it seems…
However, pimply teenagers will obviously not
be the target customer group, nor will the wealthy
banker, lawyer and advertising agency types that
drive 911s today. Instead, Nissan is counting
on Baby Boomers: aged over 50, and also over
the superfi ciality of brand image. The GT-R’s
outstanding value and performance balance,
uncompromised usability, unparalleled aftersales
care and uniqueness among cliche choices should
reel them in, the company reckons.
To help lure penta- and sexagenarians,
Nissan is making much about some of the
R35 GT-R’s handmade aspects as a point of
differentiation against its more mainstream
competition. This includes such things as a
Nissan-fi rst engine assembly process that is
overseen by one specialised technician working
in an environmentally controlled “clean room”
to ensure highest-possible quality and control,
craftsmanship levels of build quality that would
not allow even a 0.1mm gap discrepancy, and
chip-resistant paint fi nishes, to name a few.
Second-to-none customer service is another
hook to make buyers feel special. Nissan is
introducing a global maintenance regime that
will see specially trained technicians servicing
the GT-R from its 1000km service through to
the 12-, 24- and 36-month check-ups.
https://www.sau.com.au/forums/topic/190650-john-mellors-auto-news-article/
Japanese buyers will pay around $A78,000 and then $150,000 is the number in Australian dollars that may yet excite GT-R fans the most..
i guess we'll have to wait and see nissan australias real figures,
but f**k there is an extra 72k in there,
Can someone get on the ball and apply for this on the sevs regester A.S.A.P!!!!
