Hey guyz been having a problem with my idling. For an example if im stuck in traffic and i go to take off and then need to brake suddenly for what ever issue i put the foot on the clutch then brake but the revs drop below 500rpm and sometimes it stalls. So if i have hi revs and all the sudden need to push the clutch in the car almost if not stalls. I have a 96 33 with a full exhuast, pod filter and greaddy fmic. I have checked the AAC valve and that was fine there are no leaks on the piping for FMIC what else could this be guyz? would really appreciate your thoughts!! I was thinking i should just take it to a tuner, where is a good place to go in the eastern suburbs?
Cheers all
Chris
https://www.sau.com.au/forums/topic/190658-idling-issues/
Cheers all
Chris
do you have a after market BOV or even its its the stock one see if it is leaking could be causing the stalling.
https://www.sau.com.au/forums/topic/190658-idling-issues/#findComment-3433383
