  • Replies 53
I put some 'no name' brand ones in my car about a year ago now and they have been fine. Every now and then I grease them as they get a bit squeaky. I think I got them from Unique Auto sports for about $200... I think the more expensive ones would be a bit lighter thats all...
I actually ground an extra 4-5mm off the centre adjustment nut and ended up getting around 9-10deg caster...Makes heaps of difference for turn in etc. One of the best handling mods for GTSt. Tyre wear has stayed the same too!!!
cheers
Yeah you have a point. I wouldn't use any Chinese stuff that has been welded...caster rods are solid though. Replace the high tensile bolts with new ones and i would say you would be sweet for street use.
Also the caster rods are loaded mainly loaded under braking...stopping the wheel from moving forward / back ward under braking. If you are on the track and running slicks , ie very high braking forces I would run decent castor rods...
Roy,
I also recently fitted JJR (Chinese origin but they atleast are branded with warranty) upper rear control arms from Just Jap. The guy who set up the rear end looked at them and thought they were top shelf. Welding and finish appeared to be top notch... China now turns out two different qualities. 1. Really cheap shit that you dont touch, and 2. Reasonable quality at reasonable pricing.
I'd say go the JJR.
ESP sport. Got them off japanese yahoo. They are chunky, sealed, and feature a spaced down ball joint to reduce bump steer.
They are a copy of the moon face racing tie rod end.
I would never even consider running one of those rose jointed ones as i hit too many ripple strips.
Had 2 runs with JJR front castor rods ( touch wood ) with full slicks and one with re55s ( and not hadling to well ) but seem to be ok.
The welds looked ok on the units i got but lets see.
Guess that i used cheap chinese crappy brakes :D so castor rods are the least of my problems LOL
People seem to be talking about two different things. You say rod ends which makes me think of tie rod ends but you pictured caster rods Troy. Which is it?
Duncan just snapped his second stock caster rod under brakes. Maybe the cheap chinese would be better. :P
I've got the JJ ones. When I asked they said they have cheaper ones but the main difference was that the ones I got have dust covers. I've only done a couple of thousand kays on them though and one track day. Hit plenty of ripple strips though. :P
The picture that he posted is a set of after market rose jointed tie rod ends, not castor rods as a lot of people seem to think
id trust dave's version over pillowball end's for steering, especialy with the amount of track time ur car see's roy. the pillow ball joints will eventualy knock and seize up a lil. just not my cup of tea for steering components.
Only front tie rod ends. they work really well with the roll center adjusters too as the line of the lower control arm and the tie rod remain close to parallel. I haven't looked at rear stuff yet but i suspect i'd need a modded hicas lock bar to move the inner ball joint upwards rather than the outer down as it's fixed in the hub.
http://page14.auctions.yahoo.co.jp/jp/auction/s15581679 here's a yahoo link if you have a japan contact. pm me if you don't and i can give you details of the guy i use.
http://www.moonface-int.com/mfr/tie/tierod/adjusttierod.htm and the original. check the japanese version of the site for prices
hope that helps
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
