  • Replies 53
I put some 'no name' brand ones in my car about a year ago now and they have been fine. Every now and then I grease them as they get a bit squeaky. I think I got them from Unique Auto sports for about $200... I think the more expensive ones would be a bit lighter thats all...
I actually ground an extra 4-5mm off the centre adjustment nut and ended up getting around 9-10deg caster...Makes heaps of difference for turn in etc. One of the best handling mods for GTSt. Tyre wear has stayed the same too!!!
cheers
Yeah you have a point. I wouldn't use any Chinese stuff that has been welded...caster rods are solid though. Replace the high tensile bolts with new ones and i would say you would be sweet for street use.
Also the caster rods are loaded mainly loaded under braking...stopping the wheel from moving forward / back ward under braking. If you are on the track and running slicks , ie very high braking forces I would run decent castor rods...
Roy,
I also recently fitted JJR (Chinese origin but they atleast are branded with warranty) upper rear control arms from Just Jap. The guy who set up the rear end looked at them and thought they were top shelf. Welding and finish appeared to be top notch... China now turns out two different qualities. 1. Really cheap shit that you dont touch, and 2. Reasonable quality at reasonable pricing.
I'd say go the JJR.
ESP sport. Got them off japanese yahoo. They are chunky, sealed, and feature a spaced down ball joint to reduce bump steer.
They are a copy of the moon face racing tie rod end.
I would never even consider running one of those rose jointed ones as i hit too many ripple strips.
Had 2 runs with JJR front castor rods ( touch wood ) with full slicks and one with re55s ( and not hadling to well ) but seem to be ok.
The welds looked ok on the units i got but lets see.
Guess that i used cheap chinese crappy brakes :D so castor rods are the least of my problems LOL
People seem to be talking about two different things. You say rod ends which makes me think of tie rod ends but you pictured caster rods Troy. Which is it?
Duncan just snapped his second stock caster rod under brakes. Maybe the cheap chinese would be better. :P
I've got the JJ ones. When I asked they said they have cheaper ones but the main difference was that the ones I got have dust covers. I've only done a couple of thousand kays on them though and one track day. Hit plenty of ripple strips though. :P
The picture that he posted is a set of after market rose jointed tie rod ends, not castor rods as a lot of people seem to think
id trust dave's version over pillowball end's for steering, especialy with the amount of track time ur car see's roy. the pillow ball joints will eventualy knock and seize up a lil. just not my cup of tea for steering components.
Only front tie rod ends. they work really well with the roll center adjusters too as the line of the lower control arm and the tie rod remain close to parallel. I haven't looked at rear stuff yet but i suspect i'd need a modded hicas lock bar to move the inner ball joint upwards rather than the outer down as it's fixed in the hub.
http://page14.auctions.yahoo.co.jp/jp/auction/s15581679 here's a yahoo link if you have a japan contact. pm me if you don't and i can give you details of the guy i use.
http://www.moonface-int.com/mfr/tie/tierod/adjusttierod.htm and the original. check the japanese version of the site for prices
hope that helps
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
    • also, we need to know which solution worked....
